Question about Kenmore 54701 Dehumidifier
Dehumidifer not working lights are on and that it yesterday i put it on was working went to check on it and it was off
Kenmore 70 pint low temp model 580.54701400
serial 405TA031029
Unit fan runs but hums when compressor does not start
Posted on Jun 25, 2011
  • 4 Answers
Plug it in
Posted on Jun 30, 2008
Whirlpool Basement Dehumidifer is freezing up about l/3 from the bottom. Compressor will not turn off. Coils were cleaned and cleaned fan is running freely. Sitting in well ventilated area and temp...
IIt may very well be that the the air intake filter needs to be removed and cleaned. But, before doing this, turn the unit OFF & unplug it. Allow the unit to completely thaw, before removing the filter.Never operate the unit without the filter in place, As this could damage the unit.
Hope this helps you & thanks for choosing FixYa.
Sep 11, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I own a Whirlpool Dehumidifer Model Number AD 70USS1. I have a drain hose connected to the unit, however, recently the unit's internal collection bucket fills with water to the point that the...
superstee - You're having to empty it because either the drain hose you have connected to the unit is clogged or the drain hole a the hose connection is clogged. Therefor, the water is drained into the tank, rather than the drain hose. Also, the drain hose would not be any longer than 5' and must drain down, as the dehumidifier does not have a pump. It relies totally on gravity.
Remove the hose and check it for clogs. If clear check the drain hose connection, using an 18" long appropriately sized Zip Tie. Carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. Gingerly work past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. The while slowly pulling it out, rotate the Zip Tie. This will dislodge the clog. As you reach the end of the Zip Tie removal, be prepared for some water to follow. CAUTION: BEFORE DOING ANY OF THE ABOVE TURN THE MASTER ON/OFF SWITCH TO OFF AND UNPLUG THE UNIT.
The above should solve the problem for you. Please let me know. Thanks.
Jun 08, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
My whirlpool AD70USS 70 pint dehumidifier won't run , it just beeps. There is power and the bucket is in place properly, The unit is clean and nothing is plugged and the fuse in the panel is ok
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jan 17, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a whirlpool dehumidifier 70 pint and the fan runs but no longer collection of water...we have had it about 4 years.
heatman101
Oct 04, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Dehumifier blows out my electrical switch in my electrical panel.
You definitely have an electrical short in the unit and should stop using immediately. Have it checked out by a licensed electrician. It is a very real fire hazzard.
Jun 07, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
The power is coming on (lights are on) but the dehumidifier isn't starting/working.
make sure collection tank is inserted fully, maybe your switch/sensor is defective.
Apr 04, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a Goldstar GHD30 dehumidifer that I bought used last week. It's pulling 20-30 pints of water each day out of my basement so it appears to be working. The compressor only runs for 1-2 minutes at a...
yes cycles should be longer either that or the unit is keeping close to desired humidity. Also the unit is under sized 30 pint is for 400sqft. or 20 by 20 room. humidity should be 30/50 percent check your level desired room temp is 70 degrees but its a basemnt 60 works.
Jul 28, 2009 | Goldstar DH504EL Dehumidifier
Kenmore 54701 Dehumidifier Logo
245 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
