Question about Uniden TRU8885 Cordless Phone
Adding a new handset
I just bought a additional Uniden handset, my base and 3 original phones are TRU8885-2, the new handset is TRU8885-3. One of my original phones broke and we bought this one as a replacement, it is not working. We just set it on the base it charged but will never connect no dial tone. How do we pair it would the others? thanks
    Problem Solver:
  • 12 Answers
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
Posted on May 04, 2009
  • proeyesecuri May 04, 2009
    If that doesn't work. Again ensure the new phone is de registered.
    Unplug the power on the main base unit. Then press and hold the flash/find hs button while plugging the power cord back onto the unit. Keep holding the button until the charge light flashes, then let it go and press and hold the # hash button on the new handset then you will receive a message on the phone registering.
  • arldani172 Nov 08, 2010
    thank you proeyesecuri, I was about to throw the phone in the garbage, but came across your reply, now it's working.
Uniden 6.0 dect phone interchangeable with different 6.0 uniden
when the battery cover comes off there are a series of microswitches that are visible.. make sure the new ones are set with your originals..
Jan 11, 2014 | Uniden DECT 6.0 Cordless Telephone...
I attempted to register several new TCX 905s to my TRU 8866 base without success. I followed instructions from the owner's manual, from Uniden customer support, and from suggestions from this web site. ...
October 10th, 2013 at 9:19 amPROBLEM:
After de-registering handset, handset displays [REGISTRATION FAILED; UNAVAILABLE] when trying to register handset.
This worked for my UNIDEN TRU-9480-2
SOLUTION:
1) Remove handset from base
2) Remove power cord from back of base
3) Press and hold the [find hs] button on base as you plug the power supply back in; the charge light should then be blinking.
4) Return handset to base and it should register
GOOD LUCK!! HOPE THIS HELPS!!
Oct 04, 2013 | Uniden Lands Phones
HOW DO U CONNECT THE HANDSET TO THE BASE.ALREADY TRIED THE REGISTER BUTTON,DID NOT WORK.IT CAME WITH NO DIRECTIONS,WE BOUGHT AT A FLE MARKET FOR 5 DOLLARS.
Are you sure of the model number? The D1680 should register the handset when you put it on the base for 30 seconds. (You should see Handset Registering followed by Registration Complete.) Then press Talk/Flash to check for dial tone. On this model if the registration fails, charge the battery (or replace the battery and then charge that). Then repeat the registration.
The manual for the Uniden D1680 is available here: http://news.uniden.com/pdf/D1680om.pdf .
For other Uniden phones, like the DEC1060, you need to navigate through the handset menus to find the Handset Registration command. Then press and hold the Register Handset (Find Handset) key on the base for 3+ secondsThen the base and handset will synch. (Low batteries could interfere with the process.)
For the D3288, you access the base menu for Register Accy and then press and hold # on the handset for 30+ seconds. (You will see Registering followed by Registration Complete.)
Additional Uniden cordless phone manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl .
I hope this helps.
(with a flea market phone, my first suggestion is to try a new battery for the handset. They only have a given number of recharge cycles and you do not know the history. However, sometimes the chargers do fail and a new battery will not work. In that case, the phone should be replaced. It isn't worth the cost of out-of-warranty repairs.)
Jul 01, 2011 | Uniden D1680 Cordless Phone
Will the vtech interact with already an existing Uniden 5.8 ghz power max base unit and handset plus one additional handset and charger to give me four locations or just two more single handsets with...
Hi there, Your new phones will not interact with a base station from another brand of phones. If you want to use one base station, you can buy single phones of the same model and brand and those will interact with the original base station. Your new phones will not connect to the old base station Sorry, Alex
Jun 03, 2011 | Vtech CS62192 Cordless Phone
I bought 2 sets of the uniden DECT 1480-3. I want 6 handsets to work with one base. How do I add 3 handsets to a base that already has 3 handsets?
Jill,
The only logical way is to get the additional handsets to communicate with the base. And to do that you must set them to the frequency of the base. You Use guide will tell you how to set the frequency n the handsets to talk to the base. They way you set the original ones.
BUT, I doubt if this will work. Why? Because if that was the case if you and I had the same company phones, then I would stand outside your home and set the same frequency on my handset and misuse your phone. A great security risk in today's world. But there is no harm trying it out. Just set the same frequency on the additional ones as the base. If it works, then you will have that many more intercoms too. And do let me know if it works.
Apr 11, 2011 | Uniden Additional Handsets - DCT640 Phone
ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Aug 02, 2009 | Uniden DECT 6.0 Cordless Telephone...
No dial tone on one of my dual set phones model #dx18560-2
You have to register the phone to the base. Read the instructions for adding additional handsets. Regardless if it came with two handsets, one of them may not have been registerd. Sometimes it's as easy as setting the handset in the base, not the extra charge cup, for about 10 seconds. Other times you may need to use the menu on the phone and hold down a button on the base. Good luck
Apr 16, 2009 | Uniden 5.8GHz Dual Cordless Phone
Adding additional uniden phones
Register them to the base,
Your manual should show you how.
Hope this helps
Regards.
Dec 01, 2008 | Uniden Cordless Phone
Uniden handset TCX905 with base unit TRU8866-if compatible?
I just successfully registered 4 TCX905s with my TRU8865 base - it's documented in the TCX905 manual.
Be sure the handset you want to register is fully charged.
Remove the handset you want to register from its charger.
Now unplug the AC for the main base, hold down the 'find handset' key on the base and plug the AC in again, when it beeps, you can let go of that button.
Hold down the '#' on the handset you want to register, it will show 'Registering Handset...' and when it beeps, it's done - registered, you're good to go :)
Oct 11, 2007 | Uniden TCX905 Cordless Expansion Handset
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
Uniden TRU8885 Cordless Phone Logo
560 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
