Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
F-05 flashes up and water not draining out
We have a Aquarius + WD645 and its starting to coming up with a message F-05 think that its a pump problem? Where is the pump/filter as looked over the machine but cant find it????
  • 4,889 Answers
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Posted on Jul 15, 2008
F-05 is coming up on my machine is it the pump and can i fix it?
Posted on Sep 12, 2009
My aquarius washer/dryer wd645 is flashing f-07
dont warry it will be for few time then it will be ok
Mar 30, 2015 | Hotpoint -Ariston Aquarius WD645 Front...
Water wont pump out code f-05
I am not sure what that fault code means but you should be able to find the codes on the Internet.
I would suspect that the problem is a jammed or blocked or faulty drain pump. As has been sugested drain by gravity by lowering the hose into a bowl to the floor, -----REMOVE THE PLUG FROM THE SOCKET. ---- Inspect the pump, see if it is blocked or jammed, the hoses come off quite easily. Clear any rubbish out and see if the pump will then run by selecting pump and spin cycle when plugged in.
It is a good idea to take the thin pressure switch hose off at the switch end and make sure that it is clear through to the bottom by blowing down it. Make sure the machine is unplugged first.
Gently blow the switch too, you must get 2 clicks , first one with a gentle blow, and another with a slight increace in pressure.. Refit all hoses securely.
Hope that will solve your problem.. Sam.
Apr 14, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
What does h20 mean
An H2O error indicates an issue with water.
1st make sure the inlet water is turned on and none of the hoses are kinked or crimped preventing full water flow.
Another problem could be the vacuum line has dislodged from the switch.
You'll need to remove the cover and behind the soap drawer is the snmall round switch Make sure the clear vinyl hose is attached securely.
Another issue could be a clogged filter is the unit is filled and not draining. The filter is behind the fron kick plate. Be sue to drain the tub as much as you can as removing the filter with a full tub will ersult in a big clean up
Mar 01, 2012 | Hotpoint -Ariston Aquarius WD645 Front...
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wf740 washing machine
Oct 01, 2008 | Hotpoint Aquarius WF000 Front Load Washer
'test' displayed on washing machine
After pressing different buttons and waiting 10 to 15 seconds after turning the power off, I have finally found the solution.
When you have pressed the "Start/Cancel" button to start your wash programme the LCD shows "test".
You must then press the "Start/Cancel" button which will give you the normal temperature and washing time and then importantly you must depress both the "Start/Cancel" button with the "On/Off" button which will give you a different LCD message and then it will automatically resets itself.
ALL THE BEST!
Jul 31, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
482 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
