Heating & Cooling Logo
A
Anonymous Posted on Dec 13, 2010
Serial #G09007232; model #RMC-LPC80DGP; It is a construction heater & we are using it for the basement. We lit it for the first time today & on the low setting the flames are shooting out of the holes a couple of inches. My question is: are flames supposed to shoot out like that?
Anonymous
Level 2:
Novelist:
  • Expert 224 Answers
  • Posted on Dec 13, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
224
Questions
0
Helped
92165
Points
482
No it is not supposed to, please check to see that you have the chimney seated correctly. The chimney is the part that the flames heat up. It should sit flat on the steel ring around the wick.
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Does the pilot light always stay lit on this water
Many water heaters today are pilotless.
Call manufacturer with model and serial number
Gene.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Need a control knob for: dyna-glo pro propane heater. model: # rmc-tt30dgp-01, # rmc-tt30dg, # rmc-tt30gd. this is the off/low/med/hi temp. control knob.
I AM TRYING TO FIND A PROPANE REGULATOR FOR A DYNA-GLO PRO. THE MODEL # IS RMC-TT30DGP. THERE IS A NUMBER ON THE OLD REGULATOR. THAT # IS S2NTT0002-2.THANK YOU.
2helpful
Need a control knob for : dyna-glo pro propane heater. model # rmc-tt 30dgp-01, # rmc-tt30dg, #rmc-tt30gd. serial: # 09 005720
Contact GHP Group Inc, (877) 447-4768 to order a replacement regulator - MAKE SURE YOU HAVE THE PROPER HEATER MODEL NUMBER. Replacement Part Number: S2TT0001B for the RMC-TT30DGP.
Replacement cost including shipping is a couple bits over $21.
When talking to the technician on the phone, he cautioned me against rapidly opening the tank valve, which hammers the regulator (the replacement one is more robust than the original), kinda' like how water-hammer can cause damage to water pipes and/or water appliances. Open the tank valve gently, don't just whip it open (like I used to), your regulator will last a lot longer that way.
Because of the press-fit and pins used in the regulator construction & assembly, self-repair is not possible or recommended since the regulator may not seal correctly afterwards.
Dec 17, 2010 • Garden
Pilot flame will not remain lit.
u sound like u have a bad regulator
I have a dyna pro propane heater model rmc-fa100dep,will not stay lit. I took it apart. I think I need a new thermocupler. Any idea where I can get one?
YOU SOUND LIKE YOUR ON THE RIGHT TRACK,, I USE GENERIC ONES THAT FIT IN WATER HEATERS OR FURNACES THE SALE THEM AT THE HARD WARE STORE FOR AROUND $10.00 USE YOUR IMAGINATION TO MAKE IT FIT, PRETTY EASY, GOOD LUCK LEAVE FEED BACK THANKS
1helpful
Dyna-Glo model RMC-8000PGH will not stay lit
Your pilot safety is full of dust. Flush it out with shop air or rust buster. Retry
BONUS INFO
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3helpful
Dyna-glo rmc tt30dgp wont turn on
Your regulator has failed, just like mine did. Contact GHP Group Inc, (877) 447-4768 to order a replacement regulator - MAKE SURE YOU HAVE THE PROPER HEATER MODEL NUMBER. Replacement Part Number: S2TT0001B for the RMC-TT30DGP.
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
john h
Jay Finke
Jay Finke
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
