Question about Durabrand DWT1905 TV
No pwr Won't turn on, pwr up, manually or remote checked inline fuse appears to be good. Is there a reset feature ?
  • 2 more comments
  • dansea Jul 07, 2008
    Have tried all proposed solutions, still no fix. Fuses are good, no burnt traces on board no loose wires, pwr is available from ac outlet. Remote turn on, and manual will not activate. Come on guys, try harder !
    all pwr connections were tried.
  • dansea Jul 10, 2008
    Please initiate my refund. You haven't resolved my problem.
  • dansea Jul 11, 2008
    your latest solution not acceptable. You advertise to provide fixes. You didn't refund process is required.
    Genius:
  • 1,665 Answers
If you are experienced in electronics repairs you can try troubleshooting using your service manual.
Have a look at LINK (DWT1905 DURABRAND 19 TV 1 )
Posted on Jul 11, 2008
  • Durabrand Master
  • 19,396 Answers
Get a technician. DIY on TVs requires experience, a strong background in electronics, and health and safety knowledge.
Regards
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; youwill have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cablesfrom TV. Wait about 30 minutes and replug to AC power and redo the cabling.Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may haveallowed the power supply to cool. Weak capacitors often go out of spec whenthey cool, thus preventing a section of the power supply from firing upproperly again. There is a simple trick...just warm the back of the TV with ahair dryer for 5-7 mins after you have unplugged the TV. Look for the littleareas of holes in the back panel of TV. Use these as your guide at where to usethe hairdryer, but don't hold the dryer too close (say 5-6inches away). (Makesure the dryer is on High heat). If the TV doesn't turn on after you haveheated it up (like it tries to come on but then turns off) you need to unplugthe TV again, this resets it. And repeat those steps till it works. Resettingthe TV after it fails to turn on is the key. Also, just leave the TV on. Don'tturn in off. Since it is LCD, it doesn't take much power...only a few bucksextra a month for your utility bill.
4. A circuit board may crack about some of the largercomponents mounted on it. You can inspect the PCB's for fractures, and thenrepair them. It may also be poor soldering that has failed. I would be checkingfor these things first.
5. If you want to go in for a long term solution, you can easily replace thewhole power board or just change the faulty capacitors. You will have to openthe back panel and take a look. You can make out which are faulty, becausetheir caps will be swollen on top. Here's a sample pic of a bust capacitor (notsame model):
Check the specifications of the faulty capacitors, and get the replacementsfrom your local electronics shop. If you are comfortable with this, you can usea pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors.Once that is done, solder in the new capacitors carefully. If are unsure how todo this, try to get a friend who knows how to do this kinda stuff do it foryou, or get a qualified technician. Warning: If you do nothave a background in electronics repair, or are inexperienced, get a qualifiedtechnician to do it for you.
REMEMBER there are very dangerous voltages inside a TVthat can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECTTHE POWER BEFORE YOU DO ANYTHING.
Hope that helps! If nothing works, just dump the TV and buy a new one..It works out cheaper than having to try to fix it..
Posted on Jul 10, 2008
    Genius:
  • 1,226 Answers
Hello, if it is that the case, I think all probable solutions are given, all you have to do is to initiate of what is being required by the solution.
Guess your TV got low power output to boot up the system to triggering and project display. so there fore something wrong with input power. the most common causes of this fault is the transformer which serves as the supplier of all power in all the circuit spare parts. going to power regulator and capacitor. so check it if you dare to do task. (warning high voltage). if not then, it required a qualified repairman to check it personally for you.
melnavz
    Genius:
  • 2,035 Answers
Please try plugging the TV to different power supply ,if this did not work and the fuse is good and your tv and still does not on, there could be faulty power unit or main ic must have been damaged due to power surge you need to service it or if you like to DIY you need to get a service will will guide to trouble shoot the problem .
If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
http://servicemanuals.vstore.ca/
However, be aware that there are voltages inside your TV set that can kill, even if unplugged.
  • 2,323 Answers
If the TV doesn't up, it could be due to a faulty flyback transformer or a defective HOT; in today's TVs if one of these 2 components are nor functional the TV will not power up because all the voltages are taken from the FBT.
These failures are not DIY or for a begginner due to the danger of high voltages in excess of 35Kv around these parts.
Posted on Jul 07, 2008
  • Jaime Hernandez Jul 10, 2008
    Did you measure the voltages using a multimeter?
    Master:
  • 638 Answers
You have checked all the possible causes so it indicates the problem with the power supply board.just check whether any capacitors on the power supply board are bulged up.if you find any of them bulged replace them to rectify this board problem.
it should work properly for sure after that .
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jul 01, 2008
    Master:
  • 382 Answers
please check with the power cable and ensure it is connected to the Tv properly..Also ensure that other connections are proper..try to connect it with a different power supply..for ur further reference please check the connections with this manual..
http://www.usersmanualguide.com/funai/television/dwt1905
thank you!!..
    Brigadier General:
  • 3,614 Answers
If your unit has no power, check the power outlet, the electrical wires, the plug.gg and if all of this was in good... theres a possible problem on the tv powersupply area... check the fuses on that area..
  • 4,472 Answers
Have you tried opening up the back and seeing if there is a fuse on the circuit board. the board should slide out pretty easily. Check if that fuse is bad.
Keep me posted,
Lee
  • 1 more comment
  • Lee A.
    Lee A. Jul 02, 2008
    Let me know if you tried my suggestion as this should either tell if you it can be fixed or if you should have it serviced/replaced.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 10, 2008
    It is quite possible that your unit is defective and in requires service. If you need the contact information to send it in for service I would be more then happy to provide that to you. You did follow everyone's instructions and still no good? Then I would recommend service/replacement is the unit under warranty?
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 11, 2008
    Sometimes the solution is that you need to have your unit serviced. Unfortunately just because it is not the popular answer does not make it incorrect. With "high-tech" equipment like this, things like this happen quite often. It is unfortunate. No expert has control over the refund process you will want to try and contact support@fixya.com You should have found someones information helpful in the least. It is not a large amount to pay for the amount of information you have been given in a very timely manner. I hope you will reconsider and accept and rate someones solution accordingly.
    If you need any further assistance or information let me know.
    Thanks,
    Lee
How to reset my remote starter on my 2010
There isn't a reset. It could have blown a fuse. under the dash, you will find a big mess of wires, in these wires you will find 2 or 3 fuses inline. Check them. If the fuse keeps blowing, replace the remote start or take it out. Repair the wires.
Mar 06, 2015 | Cars & Trucks
How do I reset a remote starter
If it aftermarket, there could be an inline fuse blown. It is under the dash. If the fuse is good, then the controller is bad. I would take it out, because it will eventually shut the car down.
Jan 31, 2015 | Pontiac G6 Cars & Trucks
Kenwood 6.1 dvd screen won't turn on, but reset
It appears that you may have battery power but, no accessory power. Check you radio fuse in the vehicle and, behind the radio.
Feb 06, 2013 | Car Audio & Video
The battery was disconnected in my car and now my pioneer detatchable face stereo won't come on... Is there a code for this stereo?
Most aftermarket stereos do not have a reset code that I know of. Check your fuses under the dash.Iif they are found to be good you may have to remove the radio and see if it has fuses on the back of it. Sometimes it is a glass inline fuse between the stereo and the factory wire harness. Sometimes they are blade fuses in the rear body of the cd player itself.
Mar 23, 2012 | Pioneer Car Audio & Video
2001 Kawasaki VN 800 Vulcan Classic will not crank over
Hi, Fmueller05 before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Why is my Kawasaki VN800 Classic not starting
Bike Won START clicks won turn over
KAWASAKI VN800 Service Manual
OEM Parts for Kawasaki
Kawasaki VN800 Owner Manual
Nov 21, 2017 | 2001 kawasaki VN 800 Vulcan Classic
How to clear remote so I can program it again
Link to the manual
http://audiovox2.info/docs/rca_acc/man/D770_DOC_OM.PDF
Problem: The remote is not
performing commands properly.
• You must put the remote in the
correct mode by pressing the
corresponding component key (TV,
VCR, DVD, SAT, AUX1, AUX2) so
the remote knows which component
you want to operate.
• Make sure the component is “ready”
(e.g., DVD player has disc loaded;
VCR has tape loaded, etc.).
• You may have pressed an invalid
key for the mode the remote is in
(e.g., the RECORD key only works
in VCR Mode).
• If you are trying to turn on an RCA,
GE or PROSCAN component, press
the component key (TV, VCR, DVD,
SAT, AUX1, AUX2) instead of the
ON·OFF key.
• If you’re trying to change channels,
try pressing the OK key after
entering the channel number as this
is a requirement of certain models
and brands.
*There is a possibility that a
programmed code may only be able
to control some of your component
features (e.g., only turns a
component on and off). Follow the
steps provided for programming the
remote (See Programming sections
on pages 5–7). If the component can
be turned on and off, make sure you
press the CH+/CH- key to see if the
component responds. If not, try the
next code from the list.
Good Luck :)
PLEASE rate my solution
Dec 18, 2009 | RCA DIRECTV Satellite Remote Control
Power windows, interior lights and remote key entry dont work
check the fuses.Maybe inline fuse on the alarm usually lights and sunroof run off same circuit
Jul 12, 2009 | 2000 Volkswagen Jetta TDI
I stop getting power or sound to my sub
Double check your fuses. It sounds like you blew a fuse. Check the fuse for the radio aswell as the inline fuse for you amp. On some amplifiers there is a circuit breaker reset button. Check to see if your amp is equiped for that. I did find this quote for reset out of the owners manual.
Remote Turn-on
Automatically turns amplifier on when connected to the head unit's remote output. The
amplifier will turn on and off with the head unit to save current consumption. This control
also operates the reset circuit for the amplifier's protection. It must be connected with
the head unit in order to reset protection circuits.
Mar 28, 2009 | Bazooka BA1500 Car Amp
Fuse for pwr amp.
For a single Clarion APX480M, the inline fuse should have a rating of 40 amperes.
Incidentally, perhaps a copy of the installation manual would be of use to you. One is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 16, 2008 | Car Audio & Video
Durabrand DWT1905 TV Logo
147 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
