Question about Dell 922 All-In-One InkJet Printer
Paper feed skipping
The paper feed in my printer is not smooth. I get random places in documents where the ink skips down. I have tried all the troubleshooting solutions given by Dell. This is not an issue with the cartridge or nozzles. It is something with the paper feed gears.
  • ttianna Jul 02, 2008
    I actually can't figure out how to get the printer apart. I don't see any tabs or screws!
  • Neal Brown May 11, 2010
    Have you cleaned all of the rollers with a cotton cloth and isopropyl alcohol? That would be the thing to do, because there is likely build-up on some of them causing the rollers to lose traction briefly.
    Novelist:
  • 105 Answers
You should be able to access most of the rollers that would need cleaning without dismantling the printer. Once you remove the paper, you should be able to see and clean the initial rollers. When you open the cover for the inkjet cartridge removal/installation, you should be able to clean the majority if not all of the remaining rollers.
Hope this helps you.
Posted on Jul 03, 2008
Some pages offset printing
You need the paper feed tires replaced.
Feb 17, 2014 | Xerox 5500/DT Laser Printer
My 1988 Plymouth Reliant has a skip in it, when I press the accelerator, it drives smooth and then randomly skips
If tune-up, (plugs and wires) fuel filter changed, throttle body cleaned etc, hasn't been done in a while, that would be a good place to start.
Jul 30, 2011 | 1988 Plymouth Reliant
My printer skips lines when it is printing. I've tried cleaning the ink heads, but it didn't do anything. I may have cleaned the wrong thing, I'm not sure. It does it worse when I'm printing pictures...
For this operation, first get the cartridges into the center and pull the plug on the printer so it won't try to put them away while you are working on them. I haven't tried this scheme on a printer yet, but it's worked in other tight spaces: dampen a paper towel with isopropyl alcohol (rubbing alcohol). Wrap it once around the end of a strip of poster board the width of the cartridge and long enough for convenient handling, and hold it with just enough tension the paper towel to keep it in place. Slide this under the ink heads and gently wipe them with the paper towel. Flip the cleaning tool over and repeat with this side. Replace the strip of paper towel and repeat as necessary. And while you are at it, gently wipe out the head parking zone so it doesn't re-contaminate the heads.
Of course, it is possible you really are out of ink - sometimes ink feed to the heads gets erratic when the level is very low.
Jan 10, 2011 | Epson Stylus NX400 InkJet Printer
D7160 error messages showing put the papers facing down , its correct selection from our side but keeps showing the messges
Print a self-test report. See the section on how to use these solutions at the beginning of this document.
  • If the self-test report prints , try printing the original document again. If the issue is resolved, there is no need to continue troubleshooting.
  • If the self-test report prints, but the original document does not , continue to the next solution in this document.
  • If the self-test report does not print , try printing the report again. Listen for the rubber paper-pick rollers; you should be able to hear them rotating. Then, try slowly pushing the paper farther in until the roller engages to pick up the paper. Be careful not to push the paper in too far, which can cause paper jams.
    • If the self-test report does not print when slowly pushing the paper farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
    • If the self-test report prints when slowly pushing the paper farther in , try printing the original document again. The paper might not have been loaded far enough into the product. If the issue is resolved, there is no need to continue troubleshooting.
    • If the paper only feeds through the product when you slowly push it farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
Nov 18, 2010 | HP Photosmart D7160 InkJet Printer
MFC-490cw Color Inkjet Multi-Function Printer: how to send a fax...
Most of these will send a fax without even using the PC. Just connect a phone line, place the document in the proper position, usuallu print side up on newer models, and push the fax button, it should prompt you for the number. Once dialed,, the paper will feed into the scanner portion of the multi, and you will see it on the menu bar saying sending page 1, 2 etc, after if is done sending, it will dial and connect, yu should hear the typical noise a fax makes. then it will say fax sent or end or something similar, that's it, try sending one to a friend to make sure it's working. Now some simpler machines require you to open the scanner portion and lay the paper down in the glass manually, mine does it both ways. In that case just skip the feeding part, and dial wait for it to scan and send.
May 16, 2010 | Brother MFC 490cw Color Inkjet...
After Print job the printer skips and goes to next tearoff
check you manual, set the printer back to default. or it might be with the program your trying to print with. try print a test page using your driver. if it still the same. uninstall and reinstall it back to your computer to restore it to its default value
Oct 05, 2009 | Matrix Okidata Microline 320 Printer
HP J5780 Problem-Line on printed pages
most likely you have a flat spot on the roller.
that is exactly what is going to happen, when the paper hits the flat spot or a low spot. the paper stops and skips. them the print is coming out smeared.
you can get a repair kit or replacement roller from HP.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Mar 23, 2008 | Canon PIXMA iP90 Mobile Printer
WILL NOT PRINT!!!
Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. (See the illustration below this paragraph for ink tanks recommended for this model.) If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head. sj402022.jpg
Ink Tanks:
- BCI-24 Color
- BCI-24 Black
  1. Make sure the power is turned on.
  2. Lift the Scan Unit until it locks into place (1). The Print Head Holder moves to the center.
  3. Open the Paper Output Tray (2).
  4. Open the Inner Cover.
  5. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  6. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
  7. Close the Inner Cover.
    CAUTION: Press the center of the Inner Cover until the cover locks into place.
  8. Return the Scan Unit to its original position. The LCD displays a message asking if you replaced an ink tank.
  9. Press [+] to select [NO] and exit.
Jan 09, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Printer skipping lines
The printer ink that you are using are genuine?
Try Genuine ink clean the head after check nozzle , print nothing spaces , test printing pictures.
Nov 27, 2007 | HP PSC 2355 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
96 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
