Question about Whirlpool Duet GHW9150P Front Load Washer
Water in my Whirlpool Front Load Dyer exhaust..
First off, my hats off to you guys for giving such a wonderful free service to so many of us in troubleshooting some of our appliances problem.
I was able to fix my Whirlpool front load washer based on one of your recommendations. Thank You!
Unfortunately, now my Whirlpool front load dryer is acting up. It is not drying properly and when I checked the dryer exhaust there's some (actually a lot of water) water in it.
Please help. I've had both washer and dryer for about 4 years now.
Thank you and keep up the great job!
    Novelist:
    Champion:
  • 216 Answers
Greetings ireneosanch,
Has it been taking longer than normal for your dryer to dry the clothing also leading up to this? Sometimes your ventilation can become so clogged that it will cause condensation to accumulate in the exhaust hose. I would check the vent on the outside of your house and see if it is clogged and you might also have to have the actual ventilation cleaned out leading through your house.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Posted on Jun 30, 2008
H2low whirlpool top load washer turns on, fills with water for a second and stops...keeps making a sound on the sensing mode but does not get to wash mode to continue washing.
if the washer is only one month old contact whirlpool and they will give you a service company in your area to contact and it the repair will be free of charge as long as the problem is with the washer and not something that you are doing wrong or something wrong with the way that it is installed, the unit is under mfg. warrnty for one year from date of purchase.
things to check before calling would be, water connections correct? hot to hot cold to cold. are both the hot and cold water turned on?
kinked lines?
i would call a whirlpool certified repair company, they will send a guy out and if its broken they will fix it for free.
Nov 27, 2011 | Whirlpool Washing Machines
I have a whirlpool whitemagic washing machine. It makes heavy noise in the spin mode. The clothes are semi dry only. Please give me the address of your service centre with telephone number in Salem...
Sorry but FixYa is not a Service Centre. It's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web but not supplying engineers or spares ;-0)
You will either have to search in telephone directories OR stay on line and search for '(make) washer service' for instance or '(make) washer spares' and hope that you can find someone reasonably local.
Sorry again ;-0(
Good luck,
John C
Mar 29, 2011 | Whirlpool LSR5132PQ Top Load Washer
I have a F50 code on a Cabrio Washer that I purchsed less than 3 years ago. Can I have someone from Whirlpool fix this?
Sorry but we on the forum do not supply or call out service engineers direct; it's just made up of ordinary guys and gals, probably at home from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to contact a local service engineer either by searching your telephone directory or on-line. It may not be a Whirlpool engineer but any engineer of any note should be able to fix your machine.
Is there a neighbor who could recommend one?
Good luck,
John C
Mar 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
HI EVERYBODY, I HAVE AN WHIRLPOOL AWZ410 FRONT LOAD WASHING MACHINE/DRYER. PLEASE I NEED THE USER MANNUL OR INSTRUCTIONS HOW TO START IT.
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 22, 2011 | Whirlpool AWZ410 Front Load Washer/Dryer
When the water runs inside the washer always show the F1 and the machine stop.
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Sep 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
How to replace bellow on machine
my dyer shows ad on my dyer what does this code mean?
Jul 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Not enough water in a front load washer.
Water levels adjust automatically to the size of the load - no guesswork and this conserves water. If this is really a problem she should see if her warranty is still in effect and contact a service tech to check it out. She can also check with Whirlpool customer service - http://whirlpool.custhelp.com/app/answers/list
Jul 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not stop -- door locked, and it is stuck in the drain
Had the same issue with my whirlpool front load washer and it turned out to be the water pump. Believe it or not it turned out to be pricey (about $280). The service guy said that the this was a common problem with these new front load washers.
Feb 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bleach and fabric softener dispensers full of water
This is a problem common to virtually all front-loaders. Pull the dispenser drawer right out (it is designed to come right out - you might just need to give it a bit of a jiggle to get it past the stop) Remove the cover/caps from the drawer (sometimes this is a snap-on cover over the back of the drawer, sometimes a top-hat shaped cover over the siphon spigots). Give everything a thorough clean off with hot water (scrubbing with an old toothbrush helps), then reassemble. A.
Jul 16, 2007 | LG WM-2277HW Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
116 people viewed this question
Dan Webster
Dan Webster
Sal De
