Question about Sony Playstation 3 (PS3) Console
Playstation 3 wont turn on
Was playing it then the light went yellow and automatically shut down and when you try to restart it the light goes yellow and shuts down
  • Cilvie01 Jul 01, 2008
    My problem is that I was playing a movie and all was fine, then it stopped and I cannot get the cd out of the ps3. I have tried to hold my finger over the area to eject it but it goes gets blue then yellow then red. Please help
    Problem Solver:
  • 14 Answers
This is not a HD problem, it is a motherboard issue. I would send it to Sony if under warranty otherwise send it to Joegoods.com
Posted on Apr 09, 2009
    Champion:
  • 207 Answers
This is a bad issue.. if its under warranty then call sony asap.
Otherwise it may be a bad hd.. take yours out and reformat it on your computer... stick it back in and if it works your set... otherwise its a bad mother board.. i have not been able to fix this problem on 4 of the ps3s I have.. UNLESS it was a hard drive issue. best of luck!
Posted on Jul 01, 2008
Ps turns off straight away. was midway though a game when suddenly shut down and then when trying to restart the system, it automaticly turns off. no ejection option available ...or anything for that...
It sounds like yellow light of death. If you answer yes to these questions then thats what it is. I have a step-by-step instructions on how to fix it.
1. When you turn your console on, when it turns off does it beep 2 to 3 times before shutting down?
2. When it does shut down right before it does pay attention to the lights, do you see a yellow on blink once for a split second?
3. Afte the console shuts completely off does the red light just sit there and blink?
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Feb 25, 2011 | Sony Playstation 3 (PS3) Console
My PS3 (40Gb) has just shut down on me. I was playing COD Modern Warfare 2 when the PS3 just shut down and then beeped at me 3 times the red light started flashing and when I pressed the power area the...
Its called yellow light of death. Here is a link to my step-by-step instructions on how to fix.
Feb 24, 2011 | Sony Playstation 3 (PS3) Console
My playstation 3 wont turn on. the red light on
PS3 owners refer to this as the 'Yellow Light of Death' or 'YLOD'. It's quite common. The problem is caused by poor solder joints (due to overheating) on the motherboard and degrading heat sink compound on the fan.
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
I was playing a game and it just shut off. It went to a red light on the left side. If I try to turn it on, the left light goes green, then yellow and right back to red and never engages.
If it continues to blink a red light when it turns off, this is known as the yellow light of death (ironic i know). This is caused by the unit overheating causing the solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty.
Feb 05, 2010 | Sony Playstation 3 (PS3) Console
60gb ps3 wont start up.
Possibly the very common mother board failure. Slight possibility that the power supply is failed, but the capacitors in either component can be tested with capacitor tester and service manual to test for the faulty component.
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
Ps3 shutdown?
hi..Seems like your Power Supply went dead or either a faulty button.. Since those are touch pads those sometimes wear out. Another issue could be due to overheating..
thank u
rate me
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
I was playing online when the console shut down and the light on the front started blinking red. when i try to turn the console on the green light comes on and then turns yellow and then goes back to...
This could be any of a number of problems try these solutions one of which may work. If they all fail to work you can contact sony directly at:
http://www.uk.playstation.com/Support/PS3
or
http://www.us.playstation.com/help-support/PS3
  • Remove any obstructions from the vents.
  • Allow at least 4 inches of clearance on all sides for the PLAYSTATION 3.
  • Remove the PLAYSTATION 3 from any cabinets so it is out in the open.
  • Shut the PLAYSTATION 3 down completely and let it cool down to room temperature, then try running it again.
  • If the fan cannot be heard before the system shut down, the PLAYSTATION 3 may need to be sent in for service.
  • If there is no airflow from any of the vents, the system may need to be sent in for service
Hope this helps. Also be sure to rate whether this helped or not.
Jun 24, 2009 | Sony Playstation 3 (PS3) Console
Red light green light yellowlight red blinking light
From what I understand its a problem with the backwards compatibililty(the engine/drive that lets you play ps1/ps2 games)on the 60g.Sony says they have never heard of this problem yet these models are no longer in production.I have had mine for 2 years and it died today,same problem.
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
PS3 wont work
How long were you playing it? if you were playing for a couple of hours, then it could of just overheated, in which case the ps3 will shut itself off suddenly to keep from damaging something. It should work after about half an hour, adequate time for it to cool down, if not, then you might of damaged something.
Nov 21, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
96 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
