Question about Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television
Help TV is 4 years old.  It broadcasts shadows behind all text.  it also has a yellowish hue to it on the top and bottom of the screen.  It is like a belt has been tightened around the picture and it is squeezed in.  Not sure what is up - any advice is great thanks
  • Samsung Master
  • 8,617 Answers
You need a convergence PCB. your model uses the type 4 samsung convergence PC Board. You can get a new replacement at the following link and they provide free tech support and free shipping. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Jun 30, 2008
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
Lamp nearing end of life
Your best bet is to get a good TV Repair guy out to your house, that has the Sony Service Code Manual for your set. The TV Tech can access your Service Codes and clear that message out, and possibly make some adjustments that can eliminate the yellowish hue.
The yellowish hue could also come from smoking in the house or burning candles. I have 2 friends that still smoke and had the same problem with their Rear Projection Sony set. When the tech took their set apart he found the brown tar & the soot from the candles had covered the lens and much of the lamp area. They ended up getting a new set because of what it would have cost them to fix & clean the old one up.
There are at least 2 or 3 fans that pull air into every Rear Projection set. The air is pushed out the back of the set to keep it cool, so if they are sucking in dirty air, it will cover the electronics very quickly and greatly shorten the life of the set.
This is not as much of a problem for the newer "Flat Panel" (non-projection) sets because they usually do not need fans. They just let the heat rise throu the vents in the top of the cabinet.
Jan 13, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Shadow on screen
your vertical ciruit is malfunctioning
May 26, 2008 | Protron PLTV-32 Television
KDS-R50XBR1 has a yellow hue in the lower right hand corner of the screem
Hi JimmyDeps
If there is a yellow hue I would guess that this a LCD TV right ?
Which means that the blue LCD has gone and will have to be replaced.
May 13, 2008 | Sony BRAVIA SXRD HD Home Theater Projector
RCA Projection TV model #p61926
The convergence circuit is your problem and most times with this model the convergence power supply bd. is the problem.
Feb 11, 2008 | RCA P46921 46" Rear Projection Television
Purple hue on bottom of screen
You may have placed something with magnets near the bottom of the TV screen. Magnets will distort the electron beam in their vicinity. Move whatever you have there!
"de- gaussing" is the process of de- magnetising the shadow mask in the tube, it occurs automatically at switchon.
If removing magnets/ relocating TV / switching on and off does not fix the problem, it's time for professional intervention.
Feb 10, 2008 | Philips Magnavox 27MS343S 27" TV
Shadows on Rear Projection TV
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 25, 2008 | Televison & Video
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Open Questions:
Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television Logo
69 people viewed this question
Henry  Thomas
Henry Thomas
