Question about Friedrich QuietMaster Deluxe RS12L10 Air Conditioner
Friedrich QuietMaster SS12H10
The fuse/breaker blows when I turn on the unit. After I turn on the unit it makes a low humming noise for about 2 mins then the circuit breaker blows. The unit is on the same electrical outlet as it was last year, and the fuse did not blow last year.
  • kikakiki Jun 30, 2008
    I was afraid that might be the solution. I inherited this unit with the apartment, I have no idea how many btu's it is or how to replace it since its a window model and I guess was fitted especially for the window it is in. I have the manual but even it doesn't answer how many btu's (terminology ??) the unit is.
    wow thank you. i never expected this much help. one, i hope, last question. the entire unit is removed from the window, including the 2 kinda v shaped brace (brackets) and new installation, screws, drilling and all is done
    Novelist:
    Champion:
  • 230 Answers
It is probably either the Compressor and or the capacitor that has failed. The compressor will hum and pull a lot of amps when it has seized up. Sounds like it is time for a new unit.
Posted on Jun 30, 2008
  • Don Berry Jun 30, 2008
    I believe that this unit is a 12,000 btu per hour.
    New units usually come with the necessary components to mount in an average size window. In the case that the package does not come with all that you need. A salesman at the store of your choice will make sure that you get all of the right equipment that you need.
  • Don Berry Jul 01, 2008
    I wish I could be of more help for you. Unfortunately I am not sure what pieces will come in your kit. If you luck out the old brackets may match right up to the new ones. If they do not. Then just read the directions carefully and you will do just fine. The installation is usually pretty painless if the dimensions are the same.
A NEED A POWER CORD FOR THIS UNIT
Electrical Characteristics (60 Hertz)
Volts Rated: 115
Cooling Amps: 12.0
Cooling Watts: 1,343
Heating Amps: N/A
Heating Watts: N/A
Circuit Rating - Breaker or TD Fuse: 125V - 15A
Plug Face(NEMA#): 5-15P
This unit is 115vac and 15amps draw.
Find a heavy cord. ACE or Home Depoet
May 01, 2014 | Friedrich QuietMaster KS15L10...
My friedrich quietmaster does not turn on but touchpad turns on
If you are using A/C in cold weather. If there was water in base pan, the condenser fan blade might be frozen in ice. You would need to slide the chassis out 1/2 way out of sleeve to check rear condensor blade.
Aug 27, 2012 | Friedrich QuietMaster RS10J10 Air...
Describe your KS15L10 Thru-Wall/Window Air Conditioner Problem My unit also runs about 10 minutes and the kick off the 15 amp breaker. Unit was purchased 2006. Any ideas
Hello my name is Heath iot will be my pleasure to assist you. The first thing to do is unpludd the unit then go out side wioth a garden house and use a strong jet of water and blow it through the coil and get it real clean if you can then try running the unit.
Aug 29, 2011 | Friedrich QuietMaster KS15L10...
My Friedrich QuietMaster Series KS15L10 115V model will being to blow cold air and then after 5 to 10 minutes will trip the circuit breaker. We recently had a heat wave for about 2 weeks in which the unit...
Hello
Yes the northeast had temps that went past the limits of modern a/c.
Try cleaning the outside fins and coils.
Spray a product called simple green on the fins while unit is off.Leave on for 5 min.
Then rinse off with a hose.
This should keep your compressor running cooler.Also clean any filters in the inside unit.
Aug 03, 2011 | Friedrich QuietMaster KS15L10...
Ac unit turns off after about 2 mins and has error code "E3" on panel. Unit is a Quietmaster Electronic series SM21
Hello
E3 is usally a inside fan error code.Possible the fan is going bad or the unit is not wired as it should be.
Check that your incoming voltage is what the unit calls for and thhat all wiring to the unit is correct.
Jul 20, 2011 | Friedrich QuietMaster Heavy Duty SL33J30...
How to remove front cover for cleaning
I don't know too much about your particular make / model but most window units have a 1 piece front cover which is usually held on to the main cabinet with 1 or 2 screws at the sides and 1 or 2 behind the filter panel. You will need to remove the front panel to remove the vents as they are usually fitted from behind the panel.
May 31, 2010 | Friedrich QuietMaster SM18J30BR Air...
The switch on my Friedrich Quietmaster panel is
you can find them at any A/C supply house for window unites or on line. try Sears
Jul 14, 2009 | Friedrich QuietMaster SL36L30 Air...
Friedrich QuietMaster Deluxe RS12L10 Air Conditioner Logo
381 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
