Question about Canon PowerShot A710 IS Digital Camera
Canon A710 When I go to take a photo which requires flash - the cdamera focuses but then the flash signal flashes and the camera won't take the photo. Not sure what I have done.
  • 6 more comments
  • Anonymous Aug 18, 2008
    same probem, works without flash but not if flash is required.
  • suemario Dec 16, 2008
    I have the same problem - when I try to take the picture I press and no picture is taken - however if I take the flash off manual, I can take the picture
  • superstevens Jan 03, 2009
    I have the same issue. Must be common. Has anyone solved it???
  • stevetang88 Jan 27, 2009
    i have the same problem. It appears the flashing bulb is not working. As soon as i turn the flash off, the camera continues to take pictures.
  • sschulze Feb 16, 2009
    When I take a pictures that requires flash, the light goes on, but the camera will not take the picture, it works fine outside though.
  • Anonymous Mar 13, 2009
    Same here. Fully charged 2700mAh batteries but no flash. Without flash it works fine. When i get home i'll try the solution#1 posted here.
  • amandaraegib May 25, 2009
    I have the same problem. Photos requiring flash are not taken until the flash is manually turned off.
    I agree with this problem.
I have found that the camera is sensitive to battery power in that a slight fall off in voltage causes the problem. I came across a site, which I have not been able to find again, where it was stated that the contacts on the lid do not sit with sufficient pressure on the batteries to get a good contact. If you put the batteries in and look across the top, in my case, the battery +ve terminal is sitting slightly lower than the –ve battery terminal. To solve it, put a small piece of very thin plastic under the +ve contact on the lid so that it sits more proud. This has certainly improved my problem to the extent that this week the plastic fell out and the problem returned. Also I always use high capacity re-chargeable batteries. Hope this helps.
Posted on Feb 07, 2009
Red focus squares show on pictures
Disable the "AF Point Display" in the menu.
If you need a manual, you may download a copy at Owners Manual User Guide for Canon EOS 60D Digital Camera EOS60D pdf
Sep 25, 2016 | Canon EOS 60D Digital Camera
My Canon Rebel XS will not auto focus correctly. It sounds like it is trying to focus, but only flashes and will not focus or take the picture.
Those quick fast flashes usually mean the camera is trying to find contrast to take the photo but it can't. The scene might be to dark and the camera can not set it's focus and there for cannot take a picture. Move the camera slightly from left to right on the subject and see if it can manage to set focus. It's normal for the camera to give out these quick flashes as it is trying to find some sort of contrast in the subject, turning on a room light might help this?
Now when you manually focus, then the camera does not have to use it's built in auto focus sensor and will let you take a photo when you manually focus on the subject.
Sep 30, 2012 | Canon Rebel XS / Eos 1000D Digital Camera...
When taking a picture during nighttime, my camera only flashes repeatedly and does not take a photo, how can i fix this?
This is because your camera can't focus in dark. Your flash is triggering, trying to light up the subject, for the camera to be able to focus. If you focus manually the camera will be able to take a picture with out problems.
You could also light up the place you want to focus with a flash light or something, which will make the camera able to focus.
Feb 21, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Can;t get any pictures at night
hi there,
the camera needs enough light from the environment to produce good picture
in your case, have you used built in flash to support you while taking photos?
or if you don`t want to use flash, you need a tripod to ensure the camera position won`t shake
setting i usually use while taking a picture at night is ISO 100, f 22 and manual focus mode
thanks
Jan 10, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
I have to change batteries in my Canon A710 after 5 - 10 pictures, what can be the broblem and how to fix it?
Buy the best quality batteries, but NOT the highest mAhr ones. They are designed for long usage for low drain applicaions but may not be able to deliver the high currents required by digital cameras. 2100-2400mAh is said to be best. Also, use a good quality charger that can discharge and slow recharge to reconditionbatteries. I recently bought a Maha charger and some Imedion batteries. Now my camera works as it should. (previously it lost the auto-focus after a few shots). A bit expensive but cheaper than a new camera!
Dec 26, 2010 | Canon PowerShot A710 IS Digital Camera
PORTRAIT SETTING ON Canon Powershot A710 IS GIVES EXACTLY SAME PHOTO AS ON AUTOMATIC. NEED I ACTIVATE SOMETHING ELSE TO GET A BLURRED BACKGROUND?
Portrait provides extra sharp focus on the subject. It also opens the aperture some, and may in SOME cases give you a blurred backbround depending on the distance of the subject and background to the camera.
If outdoors, consider setting the camera to manual flash so that it will lighten the subject. If indoors, consider turning off the flash. You may need to provide better external lighting on the subject, or use a tripod and ask the subject to hold still during the picture.
Try increasing the zoom (best is to set it to maximum), and then adjust your distance from the subject to get as close as possible. Note that you still might be standing relatively far away because of the zoom.
Another way to experiment further with focus and blurred backgrounds is to use aperture priority (Av) mode on your dial. Use the right/left button to set the lowest "f-number" on your screen. The lower the number, the greater the aperture. All other functions of your camera will automatically compensate. Again, use max zoom in taking closeups with low "f-numbers". Also experiment with the manual focus to pay particular attention to achieving sharp focus on your subjects eyes.
You have a very capable camera. It can do what you're thinking of. You just need to practice with it. It's digital, experiment with the above techniques. Throw away the bad pics and keep the good, noting which technique worked best for the lighting and situation.
Dec 28, 2009 | Canon PowerShot A710 IS Digital Camera
Sometimes when i'm taking picture my flash wont stop blinking for a few seconds.
The 400D uses flash assisted focusing. In low light conditions the auto focus cannot get a focus lock so it pops the flash a few times so the lens has a chance to focus. You will notice this will go away when in the manual focus mode (the switch on the side of the lens).
The only way around this problem (as people in a photo think the photo has already been taken and looks away when the camera actually takes the picture) is to use a hotshoe mounted TTL Canon Speedlight (430ex or 580ex) which use an infra-red focussing beam.
Sep 04, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
It won't take a photo with flash
Ah! I just figured it out. I read that the image stabilization doesn't work as well with a flash, so I turned it off. While in camera mode (not play mode), hit Menu, then scroll down to IS Mode. There are a few options. I chose "Off." And I was immediately able to take a photo. I'll play around with the other options (Continuous, Shoot Only, Panning). Now my only problem is that I JUST changed the batteries about 10 minutes ago and it's already telling me to change them again. Ug.
Jun 26, 2008 | Canon PowerShot A710 IS Digital Camera
Photo not saved
Maybe you created a new folder on the flash-card. When connecting the camera to the computer go to Windows Explorer, and search the camera. It should come up as a drive.
A better way to search the flash card of the camera is to remove the flash card, and use a USB flash reader to the computer.
If you still cannot find the files, it is possible that you accidently erased them.
If the files are erased, I am sure your kid would like another party. This way you can invite back all his or her friends and do a re-shoot. Just make sure you have a lot of cake, and soft drinks.
Jerry G.
May 29, 2008 | Canon PowerShot A710 IS Digital Camera
Canon PowerShot A710 IS Digital Camera Logo
337 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
