Have you lost brake fluid since changing the pads...? Did you have to bleed or disconnect the brake lines when installing the pads? Sounds like a fluid leak...you should be able to trace this...If no fluid leak, did you open the system at all when installing the pads? If so, probably air in the lines...let me know if you need help bleeding both front sides...If no exposure to open lines, and no fluid loss...then the master cyclinder is bad...probably not the booster...let me know:)
The problem is not the booster, the job of the booster is to make braking easier. If the booster went out the brakes would be hard to press.
Your soft pedal is likely due to air in the brake lines. Bleed the brakes and go from there.
