Question about Samsung Yepp YH-J70 Digital Media Player
MTP Connected but not Accessible
I plugged in my USB Cord and then plug in my player, and i see the usual MTP Connected screen and i see the Digital Media Player Icon in the Taskbar and it is not seen in My Computer. Normally, it would work, but now, i get this problem. Can you help?
  • Fadil Khan
    Fadil Khan Aug 02, 2008
    Thanks a lot man... This worked...
    Scholar:
  • 93 Answers
It is simple. Forget the MTP Mode. Simply put the player on, put it on hold, press and hold the record button while you plug in the cord. It will go into USB mode, the only thing is that you have to do that everytime. Hope this works.
Posted on Aug 02, 2008
Need to mp3 out of mtp mode and into usb mode need help
in the manual it says Turn on the MP3 Player by holding the PLAY/PAUSE button. 2. Take the USB Cord and plug the corresponding ends into the MP3 Player and a Computer. 3. When connected the LCD Display will either say “USB” or “MTP”. 4. Press the “M” (mode) button to switch between “USB” and “MTP” mode. “MTP” mode will only work, when your player is connected to Microsoft® Windows® XP and Windows® Media Player 10. The MP3 Player will only work in “USB” mode when it is connected to Windows® 98SE, ME, or 2000 Professional. 5 is this helpful.Take your time sometimes these things don't work because you've missed out one step so go slow and try it two or three times before you give up
Aug 29, 2009 | GPX MW3837 MP3 Player
How do I download music on my mp3 player? I bought the mp3 player(gpxml638b) and it did not have any soft ware. I have the wire to plug from mp3 to computer, but how do I start downloading music?
Sir,
1. Turn on the MP3 Player by holding the PLAY/PAUSE button.
1. Start Windows Media Player 9 and connect the MP3 Player to your computer.
2. Click “Copy to CD or Device”.
3. In the drop-down list, on the “Items to Copy” pane, click the play list, category, or other item that you want to copy.
4. Clear the check boxes next to any files you do not want to copy.
5. In the drop-down list, on the “Items to Copy” pane, click the device that you want to copy files to.
6. Click the ‘Copy’ button.
7. Repeat steps 2-5 for any other items that you want to copy to your unit.
1. Start Windows Media Player 10 and connect the unit to your computer. On your player’s display it should say ‘MTP’. If not, then while the unit is connected press the ‘M’ (mode) button to change from ‘USB’ to ‘MTP’ mode.
2. If you have not set up synchronization between your computer
and this device, the Device Setup Wizard starts. In the Device Setup Wizard, select Manual.
3. Click Finish.
4. Select Library option. On the right pane select Sync List.
5. From the left pane you can select the Play list or Library and you will see the content songs in the center pane.
6. Select the songs from the center pane, drag and add them to the Sync List.
7. Click the ‘Start Sync’ button in the Sync List pane.
8. Repeat steps 4-7 for any other items that you want to copy to your unit.
Thanks
Good Luck
Aug 17, 2009 | GPX ML648B MP3 Player
Player does not connect using MTP USB mode
when i plug the player to the computer USB port , the player either keeps disconnecting and connecting over and over again spontaneously, or it shows up on the player' s screen as connected but the computer does not detect it.how do i fix this problem
Dec 01, 2008 | SanDisk Sansa e200 MP3 Player
When I plug my mp3 player into the Usb port, the screen goes to the connected screen for a split second. Then it goes back to the normal screen. The mps player will continue to go back and forth betwwen...
When I plug my mp3 player into the Usb port, the screen goes to the connected screen for a split second. Then it goes back to the normal screen. The mps player will continue to go back and forth betwwen the two not really connected or playing untill I unplug the cord then its normal.
Aug 27, 2008 | Audio Players & Recorders
Battery is totally flat and won't charge
The USB cable was having issues with our computer. We could download the music but it would not charge. Had to buy a USB accessible charger that plugged into the wall. I suggest the Sony AC power adapter. It's a USB power supply for Sony and iPod.
Jul 18, 2008 | Audio Players & Recorders
MTP Connected
NOT CONNECTED MP3 PLAYER
Mar 03, 2008 | RCA S1000 MP3 Player
IRIVER PLUS 3 MEDIA TRANSFER SCREEN
My understanding, as a new user, is that IRiver plus 3 only communicates with the player via UMS mode, which is not the default. Windows Explorer and Windows Media Player only communicate through MTP mode. If you change from MTP (the default) to UMS, it will reformat the player and delete all your files.
In other words, do not use iriver plus 3 unless that is the only software that you want to use. Boing back to MTP mode after a sync or download will then delete all THOSE files you just downloaded.
I just say NO to Plus 3.
Good luck.
Dec 30, 2007 | iRiver Clix Digital Media Player
Not working.
I have no charge in my philips hdd82 player. Usually I just plug it into my computer via usb and a screen shows up on the player showing its connected and it charges. Usually it comes up as an MTP device on the computer so I can add mp3s as well. Now for no reason at all, when I plug it in, it doesn't charge and the computer doesn't recognize it. The screen shows an outlet when I plug it in so I know the cord works. It just won't let me do anything. When I press the on button with the cord unplugged, I can't do anything either b/c no charge. HELP. plz.
Nov 16, 2007 | Philips HDD082 MP3 Player
MTP supported on only XP PC with WMP10
you know what man, i hav tha same problem and i fixed it!!! allu need to do is reboot ur pc install wmp10 off the cd and restart it and it will work!!
Nov 12, 2006 | Samsung Yepp YH-J70 Digital Media Player
Samsung Yepp YH-J70 Digital Media Player Logo
515 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
