Fan air pedestal fan, 16" 3 speed, made in China. Fan quit working suddenly. Checked voltage from line, through the speed selector, to motor and voltage is there. There is a 2 ufd capacitor in the circuit. The capacitor charges to the speed selector voltage but the motor doesn't turn. The motor shaft turns easily by hand. Any suggestions will be appreciated. Bill Clark
    Novelist:
    Champion:
  • 230 Answers
My guess... bad or broken motor windings. Sounds like it is time for a new motor! Good job with the diagnosing, you have some good skills!
Posted on Jun 30, 2008
Fan capacitor 250V vs 150V
Yes, the capacitor's Voltage rating is the maximum voltage the cap can take. The capacitance value is the important value to consider.
Sep 06, 2014 | Lasko 1646 Oscillating 16 Pedestal Fan...
Pedestal fan will not run.
The cost of repair probably probably will make replacement more feasible.
Mar 19, 2014 | Deco Breeze Fan. 16 in. Height Adjustable...
Furnace transformer/fan-relay wiring to fan-motor
Sounds like a relay problem but if your fan is running in heating and cooling and operating ok , leave it how you got it. It is possibly the low speed winding is shorted but will be fine with med and high. Sounds like a psc motor, doesn't use 3 speeds
Mar 31, 2017 | Heating & Cooling
Fan will not turn on, i have verified voltage through the switch. motor gone out?
yes - if you have power thru the switch and that power is also at the motor and the motor is not turning,, then the motor is bad.
but there is one more thing that I could think to check and that would be to make sure that you have power on the hot and the neutral wires -- as there could be a break in one of the lines. again check and observe voltage at the motor.
c...
Feb 15, 2011 | Patton 20" CVT Performance Pedestal Fan,...
Thermo set "heat" and "Auto
Check the fan relay. These relays are used to cut the fan on and off when the thermostat is set in the air conditioning or heating mode or when you move the thermostat to the "Fan On" position. The low voltage usually the green thermostat wire is wired to terminal #1. The low voltage common wire to terminal #3. One line voltage wire is attached to terminal #4. The high speed blower wire usually black is attached to terminal #2. When the thermostat calls for air conditioning or "Fan On" the 24 volt coil is energized, the terminals 4 and 2 close. This causes the fan to come on in high speed. When your home cools down and the thermostat cuts the air conditioner off, the low voltage coil terminals 1 & 3 are denergized, and the fan goes off. Sometimes these little relays stick which causes the fan to run all the time or will not make good contact, which causes the fan to not run in the "Fan On" or air conditioning mode.
Nov 16, 2010 | Weather King 10AJA6001AH Air Conditioner
Old system has a 6006 aquastat wiring through line voltage of fan relay on board. New Trane a/h has variable speed motor no line voltage fan relay question: How to wire 6006 aquastat to new low voltage...
Hello The easy way to bring the blower on for heating is if the thermostat has an ELECTRIC heat function or selector switch.That will bring on FAN during a call for heat.The aquastat won't be used.
Sep 07, 2010 | Heating & Cooling
Need new motor for Patton High Velocity Air Circulator Model G-1272, 110 current. After about 27 years, the motor quit. This fan is a wall mount behind my wood/coal stove facing the stove pipe. It has 3...
Do you know where I can get a replacement knob that goes on the back for low, medium and high setting? It came off when I was moving and is difficult to turn without it (i use a screwdriver at the moment).
Jan 11, 2010 | Patton (HASF1016UC) Stand (Pedestal) Fan
Aloha Breeze pedestal fan blades won't turn, but motor is humming
remove protected cover and with wd-40 or oil spray lightly behind the blade at the base oil up the bearing turn blade by hand till free put back and test the bearings get sticky from the dust
Sep 12, 2009 | Windchaser 3-way Oscillating Fan
Pedestal fan motor
you may be able to get a replacement motor in your area,but it will most likely cost as much as a completley new fan.these type motors in my area usually run around 100.00
May 26, 2009 | Hampton Bay 92650 Stand (Pedestal) Fan
Fan speed trouble on cool setting
1.check selector switch of airconditioner.
2.capacitor of blower fan motor.
3 wiring of airconditioner.
4.replace selector switch.
Feb 25, 2008 | Comfort-Aire EKTC12-150J Air Conditioner
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
