Question about LG WM-1832C Front Load Washer
Front drain leaking
My washer was giving the OE, so then I took off the drain on the front, and now the drain will not go on correctly, and it keeps leaking. What do I need to do
  • Trisha01 Aug 19, 2008
    Machine is going through half a wash and then cutting out, with rapid alarm going off announcing end of wash. display showing OE. Drum is stilll half full of water. Have tried washing in every cycle for machine to go into spin mode. Door is opening however clothes are still soaking.
  • 489 Answers
Your drain filter is not seated in properly or the rubber seal is broken.  Pull the drain filter out and be sure the area is clean and free of any foreign debris.  Make sure the rubber seal on the filter is not damaged or missing.  If it still leaks, call a qualified LG technician to assist in getting the problem resolved.
Posted on Jul 23, 2008
Filter clean drain hose straight and only 12" high still get OE code
Check for an obstruction in the pump itself. Post back the results.
Jan 21, 2013 | LG WM2277H Front Load Washer
Keep getting error code oe for the drain
Possible there is fault in the drain pump/valve and must be replaced. You can test the pump on the bench with a supply and see if this pump works without higher consumption as if so it can trip the control unit to give this error. Also make sure that the pump's sump is clean, use reverse flushing to clean.
Sep 03, 2012 | LG WM-2277HW Front Load Washer
I"m getting the OE signal.
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
Aug 12, 2011 | LG WM2277H Front Load Washer
Door will not unlock and water will not drain also get an err.code oE
Hello & Welcome to FixYa
Correct, OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter located inside the bottom front panel for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Aug 10, 2011 | LG WM-2277HW Front Load Washer
Won't drain during cycle, drain motor noise before stopping with OE drain error?
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
heatman101
Sep 03, 2010 | LG WM0642H Front Load
"OE" message
OE is actually DE - Drain Error. Pop open the little door on the bottom left of your washer, and unscrew the cap on the little tube on the left. ***Water will drain out!***
Once the water is out, unscrew the bigger tube on the right. This holds your drain filter. It is likely clogged, so clean it out and reinstall the filter and cap from the small hose.
Hopefully this fixes it!
May 02, 2010 | LG WM-2277HW Front Load Washer
My front load Tromm LG washer flashes OE message, won't drain or finish wash. Door does open
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
Dec 20, 2008 | LG WM-2277HW Front Load Washer
LG WM-2032HW front loader washer gives error goes OE and IE
"OE" is really "DE"= drain error. Clean out filter behind access door on lower left corner front panel of machine. (there will be some water in machine)
"IE" = inlet error. machine took too long to fill. clean out inlet water screens where the hoses connect onto machine.
Oct 02, 2008 | LG Washing Machines
LG WM-1832C Front Load Washer Logo
439 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
