Question about KitchenAid KSRS25IL Side by Side Refrigerator
Similar problem KSRS25, Ice maker stopped working. Red light flashes, hold the little door on left and it stays on. When I hold the door, and turn the light off the red light goes out. Is that supposed to happen? Not sure if the timer is cycling? Any tests? Water dispensor works fine.
  • clbbadger Oct 14, 2008
    I have a KSRS27CNSS. Ice maker stopped working. When this happened about a year ago the service tech came out and took out the icemaker and pushed up somewhere to reset the memory in the icemaker, but I don't recall where it was in the unit. We have short power outage blips, and he said this is what is causing the problem, which I cannot control. Can anyone tell me where the little reset button is?
    I watched him do it, and I thought I would remember, but I took out the icemaker unit and looked all around it, and didn't see the reset button that he reset with a slim long screwdriver. The water dispenser works fine, and the inner refrigerator is set on Zero Degrees.
  • kscomp0 May 11, 2010
    twins1,
    I purchased the KSRS25RS back in April and have found that this refrigerator makes an extremely annoying, almost alarm clock sound, for a good portion of the time that it is running. I am trying to find out if this sound is normal for this model. Would you say that your fridge makes that type of noise?
    Sergeant:
    Champion:
  • 330 Answers
If the noise from the bottom, probably you need Freon R-22
Posted on Jul 26, 2008
Red light flashing i push tab on the left hand side light stop flashing ice in the maker but dont fall
If the ice has not been used for some time it becomes frozen solid, defrost it and all should be ok.
Apr 18, 2016 | Maytag 25.6 Cu. Ft. Side-by-Side...
Ice maker sotp making ice / red light blinking
J, As you open the freezer door the LED on the right should flash 2X with a pause repeatedly. When you hold the left side emmiter down the light should stay on steady. If you have this, you know the optics are good unless the ejector blades are not home. First thing to check is where the ejector blades on the ice maker are parked. They should be resting in the 2:00 position. If they are not, you could have a broken module. If they are in the 2:00 positon the next thing to check would be the fill tube. You want to make sure it is not frozen over. You can disconnect it from the back and see if you can blow through the line or visually inspect it. If all of the above mentioned check out, jump start the ice-maker. Remove the quarter inch screw holding the harness cover on the right side. Remove the harness cover. Pull the ice-maker straight out but be carefull not to smash the emmitter flap on the left side. Leave the harness connected. Get a jumper wire with the ends stripped apout a 1/4 inch. Unplug the refer and place the jumper in test holes T&H. Leave the jumper in and place the ice maker on the shelf where you can close the door. Close the door and plug the refer back in. Wait 30 seconds and open the door. The ice maker should be cycleing. Pull the jumper and place the module cover back on. Put the ice maker back in the rails. It should fill at approx the 12:00 position. Let me know how you make out. Catriver.
Jul 07, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Red light blinking ice in maker and dont found pushtab on the left and the red light stop flashing
Which model do you have? Sounds like you have a optic issue but need more information. Also please include the position of the harvest fingers within the Ice maker. Need to know if they are resting in like 2 o'clock position. Thanks
Apr 18, 2016 | Maytag 22.7 Cu. Ft. Side-by-Side...
The ice maker has stopped making ice. The red light is flashing (in the freezer. Part ot technician?
Hi, The blinking red light is just a sensor that shuts down the ice maker when the door is open so that it will not dump. This should have no effect on why the ice maker is not working unless the little door that blocks the beam does not return when the door is shut again...
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 02, 2010 | Whirlpool Refrigerators
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side Ice maker has quite making ice
Open the freezer door and on the right side , make dure the slide is in the on position . If the red light flashes twice , then pauses , flashes twice , pauses , consistently , then close the flap door on the left side of the freezer . The light should go off . If these tests work , then the cut-off optics are good , and the icemaker needs replaced , due to the cubes not dumping . Also check the coils under the front of the refrig , to make sure they are clean of dust , lint , etc.
Sep 15, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
Oct 31, 2008 | KitchenAid KSCS25IN Side by Side...
Ice maker is not working
if you keep your hands out of the little beam slot on the paddel that is located on the left of the freezer and push it in the beam should shoot across to the reciever on the right and the light should stay on constant, that is if you have the switch on the right side turned on.
if it is turned on and the paddel is depressed and the light is still blinking the you need a beam kit part number 4389102
Apr 12, 2008 | Refrigerators
Ice Maker
Company needs to recall....
Mar 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
205 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
