No color - Televison & Video
  • 216 Answers
Greetings sunbury,
I would check your cable connections to the television. They might not be performing properly or they might be hooked up incorrectly. I would start with these two things.
I hope this helps!
Go Ahead. Use Us.
Posted on Jun 30, 2008
I want to change my monitor colour temperature
When you use the Colors window to select colors for text or objects in a document, you can also assign a color profile to the document. Color profiles help ensure that the colors you see in the document onscreen match the colors in the document when it's printed or viewed on another computer.
To choose a color profile for a document:
  1. In your document, select the text or object whose color you want to change.
  2. Open the Colors window.
    In some applications, you can open the Colors window by choosing Format > Font > Show Colors or Format > Show Colors. In some applications, you can also click a button in the application's toolbar or a settings pane.
  3. Click the Color Sliders button.
  4. Choose a slider option from the pop-up menu.
  5. Drag the sliders or enter specific values to adjust the color.
  6. Click the colored box next to the pop-up menu and choose a profile from the list.
If you open your document and the colors appear in a different shade or hue than you expected, the application you're using might not recognize color profiles. Try using the generic color profiles instead.
In some cases, an application may not open documents that use non-generic color profiles.
You can create your own custom color profiles using ColorSync Utility. For more information, open ColorSync Utility and choose Help > ColorSync Utility Help.
Jan 08, 2013 | Apple Mac OS X 1063 Snow Leopard Family...
How to Unlock an Ipod using Windows
If you ever accidently locked yourself out of your iPod this is the easiest way to UNLOCK an iPod
On your desktop click on Microsoft
start button, then choose Run..
type this exactly
then click
tip: use the letter representing your ipod driver, for example
J...(you can find your letter by clicking
My computer then see your ipod name under that letter)
there will be a file named
you then right click on it and choose
Rename, you then type
then press Enter
you can just
delete the file named _locked
now close window
safely disconnect usb driver (this would be either on your icon tray or you could use itunes or any other media player that has an eject button)
ps...have not tried it, but....
if you have a locked iphone or itouch, this just might work for it too.....
instead of
ipod to iphone or itouch, get it?...
Now have FUN!!!
on Jan 15, 2012 | Microsoft Computers & Internet
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. file: Download Here
1. Download and Extract the file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted file on your PC.
11. After the file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Bluish color to copied photos
Replace color cartridge:Reason: Color cartridge carries three color for color combination, in that any one of color empty or dried up color combination wont happen perfectly, result printer get mismatch colors.. In your case it might be magenta color over.. replace color cartridge to get good print outs..
Jan 31, 2012 | HP LaserJet 3050 All-In-One Printer
The alignment both vertical and horizontal are off!
Title: How to Install/Change the Print Cartridge Document ID:HO46 Back To Answers Properties 1000 Color Jetprinter 1100 Color Jetprinter 2030 Color Jetprinter 2050 Color Jetprinter 2070 Color Jetprinter 3000 Color Jetprinter 3200 Color Jetprinter 5000 Color Jetprinter 5700 Color Jetprinter 5770 Photo Jetprinter 7000 Color Jetprinter 7200 Color Jetprinter Lexmark X63 Lexmark X73 Lexmark X83 Lexmark X84 Lexmark X85 Mac OS 8.6 Mac OS 9.x.x WinWriter 100 WinWriter 150c Z11 Color Jetprinter Z12 Color Jetprinter Z22 Color Jetprinter Z25 Color Jetprinter Z31 Color Jetprinter Z32 Color Jetprinter Z34 Color Jetprinter Z35 Color Jetprinter Z42 Color Jetprinter Z45 Color Jetprinter Z45se Color Jetprinter Z51 Color Jetprinter Z52 Color Jetprinter Z65 Color JetprinterHow to install or change the print cartridge; Microsoft Windows 95; Microsoft Windows Me; Microsoft Windows 3.1x
Solution Microsoft Windows 95/98/Me:
(Applies to all printers)
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Dec 16, 2009 | Lexmark JetPrinter Z11 InkJet Color...
How to setup your EPSON FAX
1. Connect the supplied phone cord with one end to a phone jack and the other end to the LINE port of the unit. Make sure that the phone jack has a dial tone.
Note: Nowadays a lot of people are using a VOIP Service, keep in mind that the FAX was invented to work on an analog phone system (yeah the regular phone) and this new phone system might result in FAX transmission failures.
2. Default FAX settings works fine. The only time you need to configure it is if you have a phone or an answering machine connected to the unit.
3. To test if you can receive fax, go to (a free fax service) and send yourself a fax message.
4. To test if you can send fax, a friend's fax number is recommended.
on Nov 06, 2008 | Epson Stylus Multifunction Printer/...
Print server PD-301U can not work in Printer
I have one of theses D-Link PD-301U. It soes NOT support most All-in-one printers like yours. According to Epson's Web site, here are the Epson printers it supports (note the TX101 is NOT in the list):
  • Stylus 5700
  • Stylus 5700L
  • Stylus 5800
  • Stylus C60
  • Stylus EPL-5500
  • Stylus EPL-N2000
  • Stylus EPL-N2010
  • Stylus LQ-100
  • Stylus LQ-300
  • Stylus LQ-550
  • Stylus LQ-570+
  • Stylus LQ-1070C+
  • Stylus LQ-2070
  • Stylus LQ-2170C
  • Stylus Color 400
  • Stylus Color 440
  • Stylus Color 460
  • Stylus Color 480
  • Stylus Color 600
  • Stylus Color 640
  • Stylus Color 660
  • Stylus Color 740
  • Stylus Color 800
  • Stylus Color 850
  • Stylus Color 860
  • Stylus Color 900
  • Stylus Color 1160
  • Stylus Color 1500
  • Stylus Color 1520
  • Stylus Color 3000
  • Stylus Photo 700
  • Stylus Photo 710
  • Stylus Photo 750
  • Stylus Photo 870
  • Stylus Photo 1200
  • Stylus Photo 1270
  • Stylus Photo EX
  • Stylus Pro XL
Here is the link to page I am refering to:
May 14, 2009 | D-Link DP 301U (DP-301U) Print Server
Color Accent and Color Swap
Color Accent:
  • enter this mode
  • point to a color you'd like to highlight
  • press Menu
  • shoot
This will be the only color, all other colors will now be shades of gray.
Color Swap:
  • enter this mode;
  • camera will ask you to input Original and New colors;
  • use Up and Down to select how loose/precise color selection needs to be;
  • point camera to something with Original color and press Left
  • point camera to something with New color and press Right
  • shoot
Everything with the Original color will be shown with the New color.
Both of these procedures are described in the Advanced User Guide, pages 59-63 ( )
Nov 21, 2007 | Canon PowerShot SD600 Digital Camera
Can't get normal color in video mode.
We just solved this problem! Rotate the wheel button (above the Display & Menu buttons) to see the various option (Color Accent, Color Swap, Compact, etc.) and stop when you get to Standard.
Sep 12, 2007 | Canon PowerShot A540 Digital Camera
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
