Question about Frigidaire FAH125P2T Air Conditioner
A/c not cooling
My FAH126N2T1 frigidaire a/c not cooling,the fan is working,but the compressor does not turn on
    Novelist:
    Champion:
  • 230 Answers
The compressor is probably bad. But first shut off the power source and check to make sure the outdoor condenser coil is clean an able to exhaust it's heat. If you are lucky you may find a bad capacitor. It is usually a cylinder shape and has wires sticking out of the top. If it is swollen on the top or leaking a clear oil, it is bad. Be careful though. This capacitor can give you quite a jolt. It might be time for a technician or a new unit.
Posted on Jun 30, 2008
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Frigidaire refrigerator/freezer side by side not kicking on. Both freezer and refrigerator not cooling.
If the unit is not cooling in either section of the appliance, you are experiencing some form of sealed system issue. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. Unless the unit is displaying an error code, often alpha-numeric, then you would need to contact your manufacturer and then a professional to move forward accurately.
Sep 03, 2012 | Frigidaire Refrigerators
My frigidaire air conditioner model FAA060p7a will not cool the fan works fine but on cool the compressor does not kick on, if I turn the the temp knob you can hear it click behind the knob like its...
The problem here is the compressor.... it has failed and will not start. You can try to replace the capacitor and see if it will go but most likely the compressor is toast. I t will cost more to replace it then to buy a new unit.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 25, 2010 | Frigidaire FAA060P7A Air Conditioner
Had mouse get caught in fan,removed it fan still works.fridge not getting cold.any resets I can try.sounds like compressed. Comes on 2 seconds n turns off
Your compressor is faulty. When the cooling fan motor goes faulty and not caught in time, the compressor overheats and siezes.(What you are experiencing now).
Aug 23, 2010 | Frigidaire FRS26R4A Side by Side...
9-10 year old Frigidaire Gallery FRS26ZSH refrigerator stopped cooling as only the fan was running and not the compressor. Cleaned the lower coil and fan of a small amount of dust. The unit worked for 1-2...
might be your compressor relay gone bad. if the condenser fan was running and no compressor that could be the case. Also could be a bad compressor. you could try installing a 3in1 start kit. cost about $30. if doesn't start with that then compressor is kaput.
Jun 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire fac084n7a1 cooling system troubleshooting
There are a few checks that could be done, i.e. you could 'ohm the compressor out' to see if it had a 'short, or its windings are 'opened.'
Or - if there was a valve on the AC - you could tell if the system was holding it's refrigerant or not - you could also visually examine both coils to see if they were 'clean.'
But to 'make sure' the AC is operating 'correctly' will require all the components to be working - including the fan motor.
May 15, 2010 | Frigidaire FAC084N7A Air Conditioner
Compressor doesn't run
If the fan located next to the compresor works that means that the compresor relay is bad or the compresor burned out.
Jul 18, 2009 | Frigidaire FRS23R4A Side by Side...
Frigidaire does not work (freezer and cool area)
what can u hear. u should hear fan in freezer. fan in back. is compressor running. is ice in freezer on back wall. are both sides not cooling. post more info to go by
Jul 02, 2008 | Frigidaire FRS26RLECS Side by Side...
Compressor Stopping
compressor is running overloaded possible problems bad relay/overload /capacitor dirty or clogged condensers if the unit uses a condenser fan suspect a bad fan. and defective thermostats are notorious for short cycling. id check the coils first and if dirty clean up maybe that can be the major problem.
Apr 22, 2008 | Frigidaire 9 cu. ft. / 255 liter Chest...
Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
when you removed the back panel inside refrig was there any sign of cooling, perhaps only top 1 pass of the coil was frosted, or completly warm no signd of frost at all?
Feb 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire FAH125P2T Air Conditioner Logo
499 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
