Question about Mitsubishi WS-55859 55" Rear Projection Television
Turns off over and over again and agin for about 30-60 seconds sometime longer
Mitsubishi 70in tv.....I'm thinking after it gets too hot something reacts to make it shut down. What do you think.....
  • Mitsubishi Master
  • 8,617 Answers
When it shuts down press menu and input buttons both in together on the front panel of the set and see if the indicator will blink a two digit error code, then let me know the code and also verify the model number of your mitsubishi.
Posted on Jun 30, 2008
Hard to get started when powering up to watch.
definitely, something wrong with it. TV shouldn't take more then a few seconds to start, I suggest, while it still under warranty, give Sharp a call to get it fixed.
Nov 27, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Smells like it is hot or something is burning after changing bulb
Your tv is actually an Air eater. The tv itself needs a complete river of air (it looks as an exageretion) not really. I create this picture in your mind to help you to imagine all care you tv needs.
  1. Turn off the set. allow 20 minutes to cool down the set
  2. move the tv to the front and get access to the back of the tv then with a vacuum cleaner gets all dust out around the set
  3. make sure the air filter (refer to the manual) is clean.
  4. try to make sure the places were the air flows into the tv are clean and free of obstructions (back cover).
  5. finally all you can do outside the tv is done. Then when the tv is back its position make sure it "breathes" confortable. You tv has 3 fans inside (there is not a casualty)
The fresh air that goes into the system gets finally out really hot and smelly but as soon as the air flows thats normal for this tv. this is noticiable specially in hot seasons.
Apr 10, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blue and yellow ghost
Good day, BrianJack608;
Sounds like you may have a circuit problem, the convergence IC's may have failed, the STK's IC's is very common problem with TV. Before you attempt replacing them try this:
THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12596" TO ENTER THE CONV MISC. MENU THEN "8970" TO RESET.
I hope this was helpful, good luck, big IRISH.
Jul 19, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi Projection TV WD-62525
this set has 3 temperture sensors.If the set gets too hot it will shut down.
first clean the cooling fan as it may be full of dust.
if this is not the cure the one of the sensors is likely bad.
Thanks Guy9
Jun 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Hi there. i have a Sharp tv (SX68RF8) which seems to turn off (go into stand-by mode) on its own after few minutes...sometimes it stays on longer sometimes it turns off in seconds..i always have to tur it...
Sounds like something is overheating or it is getting noisy power from the mains.
Try leaving it off for a while and point a fan at it, if it turns on and stays on for longer then it is obviously a thermal issue.
Such a problem would need to be addressed by a qualified factory trained repair technician.
May 02, 2008 | Televison & Video
I keep blowing HOT on my Mitsubishi WS-65857
the high voltage splitter!!!!!!!!!!!!!!!!!!1
no dought! good luck
please mark the post with a fixya
Feb 08, 2008 | Mitsubishi WS-65857 65" Rear Projection...
Half of the screen goes black
the light engine is defective and needs to be changed..this set is not that old..contact mitsubishi customer relations to see about having it done under a customer accomodation, as they have had a lot of problems with the engines
Nov 28, 2007 | Mitsubishi WD-73732 73" Television
TV wont come/stay on
helene dear your tv need be checked for the inside there is problem in power supply need be fixed.and your will see it"for more help see expers near you.
Nov 02, 2007 | Philips Magnavox 27MS343S 27" TV
Turn on tv and after a minute it turns itself off
Check fuses F9A04 and F9A05 (5A micro fuse)on the board in the middle.If one or both are open than you need to change both the convergence IC's (STK392-570)along with the fuses.
Aug 21, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55859 55" Rear Projection Television Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
