A defective switch may interfere with your dishwasher's filling ability. Yourdishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem.
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned. -----There's no water entering the machineIf there's no water entering your dishwasher, check these:Water-inlet valveFloat switchWater-inlet valveThe water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.Float switchThe float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
My dishwasher will not fill withwater:This is often thefill valve. You cantest the fill valvecoil for continuity with aohm meter, no needle movement = bad fill valve. You can alsotest the fill valvefor 120 volts at the fill valve with avolt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like thefloat and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace thefill valve. You will need toremove the access panelsto get at the fill valve. Dishwasher fill valves also have ascreen builtinto the valve entrance, this can also get allclogged upand need to be cleaned.
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
