Question about Refrigerators
Water gushing out of the back/top of the ice making section of the fridge
  • 1 more comment
  • mmcoughran Jun 30, 2008
    We have water gushing out of the bottom and leaking out of the ice maker and freezing the mechanism.
  • osci Oct 12, 2008
    water gushing out of ice maker on maytag plus #rsw2700
  • gbur8 Oct 14, 2008
    The water fills the tray and stops but later after the ice freezes the water starts again and overflows the tray. Sometimes water overflows the tray before the ice freezes. At other times the water freezes in the cup that funnels the water into the tray; once this happens water again overflows into the ice despencer.
Http://www.applianceaid.com/ice-fill-adjustment.html
You can try this. There might be too much water filling the trays, resulting in leaking.
Posted on Jul 13, 2008
Fridge will dispense water and ice but will not make ice
You question " Fridge will dispense water and ice but will not make ice" If its not making ice then how its dispensing the ice. This is bit confusing me,-------- as per your question i assume you mean to say, that its dispensing the watyer but its not making ice. ------------
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Apr 26, 2011 | Refrigerators
Water leaking from bottom
Between your freezer section and refrigerator section there is a draintube that allows water to flow from the freezer to the fridge during defrost. You will need to remove the rear wall of the freezer to access the freezer part and the center console of the fridge if one is there. Once you have determined that tube is cleared of ice you will need to continue tracing where the water flows which is usually at the top of the fridge section in the rear center. It goes out the back wall there. Make sure thats all cleared and pour a small cup of water in the freezer part to be sure its clean. Observe the water flow all the way out of the tube to the lower part of your unit into the drain pan which is located at the very bottom or in the rear on top of the compressor.
May 22, 2010 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Water is leaking into fridge, ice maker making hollow ice
Make sure when the icemaker fills its not causing the leak ...... other than that you have a clogged drain in the freezer section .... easiest way remove everything unplug for 24 hrs with door open .... manual defrost ....hehehe ..... plug back in u should be ok if reoccurs call for service
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
There is water dripping filling up the bottom under the salad container. The model is a LRTN22311TT.
Remove contents of fridge and check the drain line running down the top back of the back of fridge and follow to lower section of fridge (usually a back ledge or under the crisper sections) and locate a small round drain hole. Also, check to see that the drain collector (funnel looking thing at top back of fridge section) is located under the freezer defrost drain opening, to allow water to flow through the fridge into the drain pan under the fridge.
If something has obstructed the drain funnel, path, tube, or lower drain hole, remove the blockage to allow water to drain into underneath of fridge into drain pan for proper evaporation of water produced from the usual daily defrost cycle of fridge/freezer.
If that is not the problem, it could be that you have a leaking water supply line for your ice maker and you'll need to see if the freezer is allowing excessive water to flow out of the ice maker into the fridge section.
Another simple check/solution is that the fridge is not properly leveled, meaning that the front of the fridge should be slightly higher than the rear to allow for proper drainage and self closing of the front doors. This will help keep the water flowing in the built in channels and drains.
A perfectly level fridge isn't the right way to install most moveable refridgerators, while built in fridges (Sub Zero, etc.) are designed for plumb and level installations for proper functioning and use.
Apr 09, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Water gushed out freezer door, possible solenoid problem?
The drain is clogged. The drain is usually located inside the freezer on the bottom shelf to the rear. Use a meat baster and a solution of 1 tsp. baking soda and 2 cups of hot water-not boiling to unclog the drain. You probably also have about 1/2 inch of ice build-up on the bottom shelf. This will have to be removed first.
Nov 13, 2008 | Kenmore 50522 / 50524 Side by Side...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Drain hole in top fridge section flooding and icing up under vegtable storage draws.
maybe you fridge is tilting to far forward some times a fridge needs to lean back slightly only by 5 degs so adjust the foot t the front. this will mke the water flow towards the back and also help keep the doors sealed better
Dec 10, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
