Question about Motorola Mobility H700 Wireless Headset
Blue light will not stay lit
I am trying to connect the my motorola headset bluetooth to my phone, does not work and i cant find the user manual.
I have it for a year but I can't use I not have any idea if is the battery please...
  • 1 more comment
  • pmarin Jul 01, 2008
    the indicator light not stop blinking the light never become steady I after I press and hold.
    Thanks
  • GINA VAUGHAN Mar 12, 2009
    The indicator light will not stay steadily lit in pairing mode. It never remains purple or blue. I'll hold down the call button, it will stay purple for maybe 4 seconds and then turns off. I've also tried holding down the call button, releasing when it becomes purple then open the boom...still nothing. It is charged, so I don't know what the problem is. Help!
    Indicator light will not stay lit in pairing mode. I hold down the call button, it will remain purple for about 4 seconds, then turns off. I've tried holding the call button, releasing when it turns purple, then open the boom but it still won't remain lit. It's fully charged. Help!
Good
Posted on Oct 20, 2011
Thanks to Latoof, his solution really works
Camilo
Posted on Jul 02, 2008
    Sergeant:
  • 287 Answers
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset
boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator
light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The
indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Posted on Jul 01, 2008
  • Dave Jul 01, 2008
    make sure the battery is fully charged. I have had a couple of these and they do not last for ever... the battery will eventually stop taking charge then it's time to send it off to the recyclers
Motorola Flex 11 HD blue light doesn't stay lit when turned on
The light should be visible if you are on active hold. Just try and see if the device works as is. If so you answered your own problem. If not, contact the manufacturer for a fix.
Jan 20, 2014 | Motorola Mobility MOTOROKR S9 Wireless...
I am trying to pair my My Touch 3g phone to my H680, but I cant. I previously had a h17 connected to my cell phone too but it was not paired. Now when I try to pair the 680 it tells me that it is having...
In order to pair your headset with your phone, when you turn it on for the first time, its indicator light should be steadily lit in blue, thus indicating it is in pairing mode. If it has been paired to another device before, make sure that that device's bluetooth radio is turned off. If the light is not steadily lit, turn your headset off, wait for some 10 seconds, and turn it on again. Anyway, whilst its light is steadily lit, make you phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (indicator light starts flashing in blue). You see, the pairing procedure between any two bluetooth enabled devices should be performed just once. All subsequent connections between them should be achieved just by bringing they within each other's range, with their bluetooth radios turned on. At most, a simple press on the headset's call button should do.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Please, let me know if I can help you any further.
Regards, Carlos
May 05, 2011 | Motorola Mobility H680 - Headset -...
I need help pairing my motorola h500 to motorola i580 phone
  1. Make sure your phone's bluetooth is on.
  2. Go to MENU > SETTINGS > CONNECTION > BLUETOOTH LINK > SETUP.
  3. Scroll to power then press change.
  4. Scroll to ON the press select to turn on the bluetooth feature. Bluetooth feature remains ON until it is turned off.
  5. With the headset power off, press and hold the CALL button for 6-10 seconds until the blue light indicator turns on and remains steadily lit. If it does not stay lit, turn off the headset. To turn it off, press and hold CALL button until blue light stops.
  6. While holding the CALL button on the headset, on your phone select MENU > SETTINGS > CONNECTION > BLUETOOTH LINK > HANDS-FREE > LOOK FOR DEVICES. The phone lists all bluetooth devices it finds.
  7. Select Motorola H500.
  8. Press OK or YES to pair the headset with your phone.
  9. Enter the passkey 0000.
  10. Press OK.
Oct 08, 2009 | Motorola Mobility H500 Headset
How do i place a h555 motorola bluetooyh in pairing mode
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Call button
towards the microphone to initiate easy
pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate
headset is in pairing mode.
Step B - SET YOUR PHONE TO LOOK FOR
YOUR HEADSET
On your Motorola phone, press (Menu) >
Settings > Connection > Bluetooth Link >
Handsfree > Look for Devices.
The phone lists Bluetooth devices it finds.
Select Motorola H555.
Select OK or Yes to pair your headset with
your phone.
Enter the passkey: 0000
Select OK.
When your headset successfully pairs and
connects with your phone, the indicator light
changes from steadily lit to flashing blue.
Troubleshooting: Make sure that any devices previously pairedwith the headset are turned off. If the indicator
light is not steadily lit in blue, turn off both the
other device and headset, wait 10 seconds,
then turn headset back on. Wait for the indicator
light to become steadily lit in blue, indicating
the headset is now in pairing mode.
User Manual
Aug 22, 2009 | Motorola Mobility Bluetooth Hands Free...
How to connect motorola skywing
The default passkey is usually 0000 (4 zeros)
Jul 23, 2008 | Motorola Mobility H700 Wireless Headset
I need instructions how to connect my h350 blue tooth to my lg cu400 cell phone
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
again.
The default PIN or passkey is 0000 (4 zeros)
You need to enable bluetooth on the phone and go into pairing mode, search for devices or similar
HIH
Jul 12, 2008 | Motorola Mobility Bluetooth Hands Free...
Motorola Bluetooth® Headset H555
This will vary depending on the model of your phone. First off, you need to ensure that you are using a bluetooth enabled phone.
On your bluetooth headset, hold down the power button down until the power light stays lit. This may take 5 seconds or more. Now your bluetooth is in pairing mode.
You will need to enter the settings and tools menu. From within that menu, you need to find either "connections" or "bluetooth" and select. Make sure bluetooth is enabled. There will be an option to add a new device.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code. This pin code will be 0000.
Jan 14, 2008 | Motorola Mobility Bluetooth Hands Free...
Motorola H350 User Manual
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Jan 08, 2008 | Motorola Mobility Bluetooth Hands Free...
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Attn!!! Purple light wont stay on long enough to pair.
DO THIS:press hook button until light remains on solid (mic folded in)fold mic out while light is still solid then pair.
Dec 08, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
278 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
