Question about Actiontec (GT701) Modem
Putting actiontec into bridge mode
I have an actiontec gt704-wg and want to use a new dlink dir 625 for the wireless. I have been able to get the action tec into transparent bridge mode but the dlink cannot detect internet any thoughts
5 Suggested Answers
SOURCE: password
Press the reset button on the back for around 45 seconds, wait for the router to start up (around 3 minutes) then connect your computer and login with the default username admin and password admin. Make sure your computer is set up to automaticly aquire a ip address and point your browser to http://192.168.0.1 to log in and set up the router. The user manual for your router can be found here
Posted on Jan 15, 2008
kakee
  • 1268 Answers
SOURCE: how to find old security key in case GT704-WG?
You simply access the router's setup page by going to Internet Explorer and type http://192.18.1.1 it will prompt your for password, try admin by default. You can change the security key under the wireless tab and look for wireless security
Posted on Jun 20, 2009
  • 8 Answers
SOURCE: New iMac very very slow loading pages with Actiontec GT704-WG
I have seen this before and this has cured it:
Check the DNS settings in the Network panel and enter a manual DNS that matches the base address of the router (192.168.0.1 for this router).
System Preferences > Network > Ethernet > Advanced > DNS. Click the + sign and add 192.168.0.1. Click OK, and click Apply on the next screen.
macs2u
Posted on Aug 12, 2009
Geekman
  • 32281 Answers
SOURCE: I have a dsl modem and an actiontec gt701-wg gateway
Yes this is a normal method to setup a wireless network.
To set-up and secure the wireless router from unauthorized access, follow these steps :-
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Posted on Oct 31, 2009
SOURCE: I need a WEP code for an Actiontec GT704-WG.
You MUST re-set up the Router again, login with a browser, this time copy paste WEP/WAP code into a notepad document. for use on client (Wii) now after setting up the router, check the SSID, the NAME of the WiFi Connection. Save this in router. Then on the Wii, use that written down key, to put the key into the box, this will allow access.
http://www.actiontec.com/support/product_details.php?pid=40&typ=doc
Get your manual from link above, that will help you set it up.
Posted on Mar 28, 2010
I have a Westell DSL modem & a D-Link DIR-625 wireless router. Everything has worked fine for years but a few days ago the Internet connection went down. I contacted AT&T for support. During the...
you need to configure the dsl modem to be on bridge mode after you did it successfully. that is the time you configure your d-link for you to connect to the internet.
call first your ISP to configure the modem to Bridge mode after that call your manufacturer of the dlink for them to configure your connection
Jun 11, 2010 | D-Link DIR-625 (790069292637) Wireless...
macs2u
Aug 04, 2009 | Actiontec GT704WG Wireless Router...
How to find old security key in case GT704-WG?
Jun 20, 2009 | Actiontec GT704WG Wireless Router...
Changing Wireless Channel on GT704-WG
David,
Log into your Router, navigate to the Wireless Setup page, and under Wireless Settings, you can enter the SSID and channel to broadcast.
The full manual can be located at the link below.
http://support.actiontec.com/doc_files/GT704-WG_NCS_User_Manual_3.0.1.0.6.0.pdf
Mar 05, 2009 | Actiontec GT704WG Wireless Router...
D-link dir-625 in bridge mode
Try disabling the routers dhcp undet the network setting and make sure that the ip address is in range of your own network.
Jan 05, 2009 | D-Link DIR-625 (790069292637) Wireless...
GT704-WG with Verizon firmware
I just flashed my verizon modem FT704-WG with the actiontec update upgrade301060gt704wg.img. I then selected "Obtain an IP Address through DHCP" and bam away we go... working better than verizons version.
Jan 21, 2008 | Actiontec GT704WG Wireless Router...
How to Configure Router
you can download the user manual from here as to post the full set up would take a while, if you do not have the drivers then click on the second link to download it has there is a set up wizard you can use. http://www.actiontec.com/support/broadband/gt704-wg.pdf http://www.actiontec.com/support/broadband/gt704-wg_driver_updates.html
Jun 30, 2007 | Actiontec GT704WG Wireless Router...
Actiontec (GT701) Modem Logo
1,713 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
