Question about Tomtom GO 700 GPS Receiver
My tomtom won"t turn on
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
Posted on Dec 13, 2010
SOURCE:
My Tomtom 300 Go won't charge?
It appears that the battery will not hold a (good) charge anymore. If it is still under warranty, contact TomTom to address that problem. They may replace the unit for you.
It is not unusual for (rechargeable) batteries to loose it's capability to hold a good charge if it is plugged in (to a power source) all the time, even while it is not in use.
May 06, 2012 | Tomtom GO 300 GPS Receiver
I require a mains charger for Tomtom 4n00.001. I need to charge it from home
You can buy a Tomtom main charger but they are fairly expensive.
You can use a Main powered USB charger along with your normal PC Tomtom USB cable: it should ideally be rated at 1 Amp or more.
You might even have a suitable main USB charger on hand now as they often come with generic MP3/MP4 players and some mobile phones: I use my Huawei U8150 or E585 modem charger for that purpose myself!
Hope it helps.
Sep 23, 2011 | Tomtom ONE GPS Receiver
TomTom GO 910 won't turn on.
Two possibilities:
- if someone has used the wrong charger, and connected it to a 12V supply, the mainboard may be damaged. In that case, you need a replacement.
- the battery may be discharged. Even if the green light is on, it doesn't necessarily charge up. Try pushing it hard onto the mount for a few minutes, then see if it will turn on.
Feb 08, 2010 | Tomtom GO 910
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
My tomtom one no longer recognises the car charger.I have purchased a new one from a dealer and it won''r make it charge.I can only bharge it with my bomputer hook up cable...what can I do now?
Seeing as it charges from the computer
I doubt that it is the tomtom.
I would suspect either the outlet in your car or a posible problem with the lead even if it is new.
Aug 28, 2009 | Tomtom ONE GPS Receiver
Gps won power up when car charger burn frm fuse
Unfortunately it sounds like when the car charger went bad it also did in the board on your tt. It would be cheaper to just purchase another unit than to get this one repaired out of warranty. My advice would be to sell it on ebay. People buy these all the time for spare parts.
Hope this helps
May 09, 2009 | Tomtom GPS
Tomtom won't turn on or off. So I can different screens
does the socket in your car stay powered on even when the car is turned off most likely not and you just need to charge your device will itcome on when it is in the cradle for the computer
Dec 27, 2008 | Tomtom ONE GPS Receiver
Tomtom one repair
If the green light does not even come on when you plug in the charger you must have an issue with the logic board. Did the GPS get wet or did it drop, was there anything else the preceded the moment it stopped working? There is a company that sells GPS logic boards for TomToms : GPS Repair
Sep 20, 2008 | Tomtom ONE GPS Receiver
TomTom 910 won`t turn on
try charging both in the car and on the home charger
try a doft reset
www.tomtom.com.7134
Jun 22, 2008 | Tomtom GO 510 GPS Receiver
Tom Tom One Doesn't Turn on
in that case you will have to take off 4 screws on back the navigation system
easily take the back piece apart and unplug the battery wait couple a seconds then plug it back
it should work
Apr 20, 2007 | Tomtom ONE GPS Receiver
Tomtom GO 700 GPS Receiver Logo
453 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
