Question about Sony MHC-GX25 CD Shelf System
Extension wires for speakers
I need to lenghten the speaker wires. The origional built in wires are gray and gray with a black line. Which of the two wires are the posive wire?
If there isnt a line up the postive, then usually the wire on the inside is a different colour, ie. bronze/copper for positive and silver for neg.
Strip a section from the base and take a look!
Posted on Aug 09, 2009
Speaker hum
Did you swap speaker to a different channel and put another in its place to see if the problem follows the speaker or stays on that channel? That would me my next move if it's possible to do. Let me know.
Dec 06, 2013 | Audio Players & Recorders
I have an older JVC Shelf Unit with the main control unit in the middle and a left and right side speaker that contains a built in subwoofer on each side, lately the Speaker cuts in and out at higher...
It's one of three things things:
First, examine where the speaker wires are plugged into the receiver. Are any of the copper strands touching one another? If so, remove the excess stripped wire and reinsert it. Problem solved.
Test two: bad speaker. to test, swap the speakers (hook the right speaker to the left speaker jacks and the left speaker to the right speaker jacks). If the RIGHT side now cuts out, you have bad speakers.
If the speaker on the LEFT jacks still cuts out, your amplifier is going bad (which could cost between $50-$200 to repair).
Jul 01, 2011 | JVC Audio Players & Recorders
How do you fix the cord conectors for the speecers & how to you fix the inside when that 1 of the lines have came uncanected
you need to stripe the ends of the wires for the speakers there will be 2 there will be markings such as lines on the positive wire that goes into the red slot the other wire(negative wire) goes into the black slot. and you wil be good to go
Hope this helps
Positive feedback always welcome :)
Mar 03, 2011 | Philips FWC527 CD Shelf System
To connect speaker wires to unit there are blue wires and black wires. where do I attach them to the unit
hi,
connecting right speaker.
1.connet the speaker cord with the plug to the speaker high freq right (R) terminal
2. connect the speaker cord with white strip to the speaker low freq right (L) + terminal and its black cord to the -- terminal
do the same for connecting the left speaker to the speaker high freq left (L) and speaker low freq left (L) terminals
ok
Jan 05, 2011 | Aiwa Z-L700 Shelf System
Where do I find Speaker Connectors both Male and Female to make up speaker extension lead for Sony CMT-HX80R Hi-Fi
There is no speaker cable extensions available for your system but if you goto www.BogueEngineering.com you will find speaker cables with the special connector and they come in any custom length you need, even if you need 100 feet speaker cable you wil get it and they also come in many different heavy duty gauges. You can also email these guys at
Bogue-Engineering@live.com
Cheers!
Apr 17, 2010 | Sony CMT-CP505MD CD Shelf System
Need to find which is the ground wire for the speakers from aiwa cx-naj14
The ground wire is the one with either the stripe, running the length of same, or the black wire, or the grey
wire or the green wire or whichever of many coding systems in use on your speaker leads and always
designated on the back of the speaker as the (-) negative lead and on the back of the unit, if using RCA
PLUGS as the body, not the tip of the lead.
Apr 17, 2009 | Aiwa Audio Players & Recorders
Main Speaker cables
well man i would clip the ******** with a few inches of wire attached so you can strip both ends where you cut and splice in a piece of wire it will function properly
Aug 13, 2008 | Sony MHC-GX9900 Shelf System
Speaker switch box
Hi Dave. I guess it would be helpful to know model of the system. Could you send us the model number and make? If I have this information I can get you up and going!
Feb 02, 2008 | JVC VS-DT2000 CD Shelf System
No bass...
i have the same problem
Dec 27, 2007 | RCA RS2652 Shelf System
Sony MHC-GX25 CD Shelf System Logo
110 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
