Question about SanDisk Sansa c240 MP3 Player
Sansa c200 I cannot get my computer to recognize the players. I opened and put back the battery and now all I see on the player screen is a picture of a battery.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 08, 2008
Its not starting
Plug the drive into a computer and see if it is recognized and charges.
If so wait for it to charge and then:
1. Unplug the drive. 2. Remove the back casing 3. Remove the battery 4. Wait 15 seconds 5. Replace the battery and casing and press the power button.
If the computer does not recognize the MP3 player its days are probably over. If it does not charge the battery is likely broken.
Mar 05, 2011 | SanDisk Sansa c200 MP3 Player
How do you put music on it? I have it connected.
1. Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer. 2. Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player. 3. Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player?s memory are displayed. 4. Open a folder containing music files that is stored in your desktop computer?s memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player. 5. Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list. 6. Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Oct 07, 2009 | SanDisk Sansa c200 MP3 Player
Freezes on boot up at the SanDisk logo
From the sansa site:
STEP 1 – Reset the device
  1. Slide the Power switch up and hold it for approximately 20 seconds.
  2. Release the Power switch once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
If this article did not resolve your issue, please contact us at support@sansa.com.
Other possible solution.
Plug the unit in to the computer.
Even if it won't boot it might still recognize it as an external storage device.
If so, open My Computer and right click on the player. Select format from the menu that appears.
Select the FAT file system from the options that appear.
W A R N I N G!!!! This WILL erase all data on the device, please make sure you have a backup copy of your music and or other files BEFORE proceeding with this fix!! /W A R N I N G!!!!
Now, once you have the unit formatted, download the firmware for it from the sansa website at www.sansa.com.
Jun 28, 2009 | SanDisk Sansa e250 MP3 Player
Sansa c240
Sansa c200 series – Computer/OS Not Recognizing
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=8VPwlRmj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzQsNzQmcF9wcm9kcz00JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jMjAw&p_li=&p_topview=1
-Tha Mp3 Doctor
Jul 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
It doesn't turn on!!
I'm having the same kind of problem. Its really wierd and i'm really worried about it bcoz its my first mp3 player.
Apr 15, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa c200 frozen
Have you tried to reset the device by holding the power button?
Jan 05, 2008 | SanDisk Sansa c200 MP3 Player
Battery
pages 11-12 of the user guide explain this (with pictures)
Sansa user guide
Nov 25, 2007 | SanDisk Sansa c200 MP3 Player
Help!
We have two laptops and one desktop in my house and two 2GB Sansa c250s. My laptop recognizes my sansa c250 differently than our family's desktop (i.e. on the desktop i can't view certain folders/ music files that i transferred from my laptop to my player). The second laptop doesn't recognize mine at all, but it DOES recognize my sister's sansa c250.
my suggestion? try a different computer! and then KEEP using that computer for adding/ deleting files.
Oct 17, 2007 | SanDisk Sansa c200 MP3 Player
Sansa c200
-Tha Mp3 Doctor
Sep 05, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa c240 MP3 Player Logo
126 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
