Question about Microsoft Windows XP Home Edition
Blue Screen When I start up computer I gat a blue screen with Stop:0x0000007F. I can only run windows on safe mode. Help ! its driving me crazy .
  • kkell1 Jun 30, 2008
    No have not added any new hardware
  • nsindian
    nsindian May 11, 2010
    have you recently installed any new hardware?
  • 108 Answers
Please contact microsoft for the same or contact your vendor form where you had purchased the machine
Posted on Jun 30, 2008
  • Karamveer Tanwar Jun 30, 2008
    start the computer in safe mode and go to Start>>Programs>>Accessories>>System tools and do a System restore and then start the computer in normal mode to see if it helps.
    Also let me know the exact error that you get on the blue screen if the above mentioned steps doesn't resolves the issue
COMPUTER - BLUE SCREEN
what is the error of the blue screen showed? etc Stop :0X00000FE
Jun 08, 2012 | Dell Computers & Internet
I install windows xp profetional in g62_b39se it installed compeletly but when insatll completed, an blue screen apeared whith stop massage
Power on Laptop & Click F8 Button then Safe Mode Menu Visible Select "Disable Restart After System Failure" Then U Wacth And Reply Error Msg And Error Code Fully.
Best Of Luck
May 07, 2011 | Computers & Internet
My acer aspire one zg5 got the blue screen. after loading the windows, it will stop then flash the blue screen then restart again and again. what will i do? somebody say my netbook needs to reformat. but i...
Follow these steps to fix a Blue Screen in Safe Mode
Once booting start, select "Safe Mode" from the boot menu.
Scan your hard drive by running your antivirus software . If the program locates an infection, move it to your vault or follow the on-screen instructions. After program completion, if a virus was removed, attempt to reboot your computer and see if this clears up the problem. If not, restart your computer in safe mode.
Restore your computer to a previous point. Click on the "Start" button. Select "All Programs", "Accessories", "System Tools" and finally "System Restore". Choose a restore point on or before the last day your computer worked without error. Finally Reboot your computer to see if it loads correctly.
Mar 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have acer aspire when i turn it on only blue screen come on how can i fix it
Hi !
Blue screen means that your Hard Disk drive is damaged or dead and it cannot be repaired. Solution is to replace new the hard disk.
Good Luck and thank you for using FixYa !
Jan 06, 2011 | Acer Aspire One PC Notebook
Blue screen error
The most frustrating blue screen computer errors are basically caused by some physical faults such as faulty memory, power supplies, overheating of PC components, or hardware running beyond its limits, device driver conflicts etc.
If you see the blue screen and halts occur in boot process, and also notice some specific error message appear on your screen, this indicates a serious issues most probably due to inappropriate device driver or firmware .Blue screen is really an annoying issue and creates a lot of trouble to the end user.
Aug 27, 2010 | Microsoft Windows XP Professional SP2
Can only start acer pc in safe mode -window consistency check.
Microsoft indicates that this issue can be a hardware failure.
http://support.microsoft.com/kb/137539
You can try using only 1 memory module if system has 2, or try reseating if it only has one. If system works normally with 1 module, replace the other
Mar 15, 2010 | Computers & Internet
Can only start pc in safe mode keeps doing windows inconsistency check. Seems to be on loop. Blue screen shows Tech info stop 0X0000007F (0X0000000D, 0X00000000, 0X00000000, 0X0000000. Windows XP. Please...
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Blue screen on start-up saying 'stop: c000007b bad image' etc
The odds are, you will need to replace the HDD. Best odds for data recovery are to get a new drive and a universal HDD adapter (here is an example: http://www.amazon.com/Universal-Adapter-2-5IN-3-5IN-Sata/dp/B000QY9KIS)
Reinstall you operating system on the new drive then connect the old drive via the adapter and see if you can access the files you want to retrieve.
If that doesn't work, then you'll likely need to consult an expert like Drivesavers 800-440-1904 and see if you can afford a recovery of the data
Jun 13, 2009 | Dell Inspiron E1705 Notebook
Errr...sounds like fun.
OK well I would stop trying to get Windows back in working condition until after you backup your files.
The easiest way is to remove the hard drive from the system and place it into a usb enclosure.
Backup the files and then reinstall windows.
If you try the band-aid method you'll just end up wasting your time.
Hope this helps.
Jun 13, 2009 | Dell Inspiron 1300 Notebook
Okay my sony laptop windows vista crashed . it turns on but then it goes to a blue screen , i can get it to safe mode & i tryed disabling stuff but it like wont restart either , it goes from a blue screen...
Boot into safe mode by tapping the F8 key on startup, once you're in safe mode, run the system restore tool (usually in start -> program files -> accessories -> system tools -> system restore) to a few days earlier and restore. After that, install an Anti-virus application, such as AVG Anti-Virus, and scan your computer to remove the problems.
Hope this help!
Robert W.
Jan 09, 2009 | Computers & Internet
Microsoft Windows XP Home Edition Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
