Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error F 02
I have this error occur ... does anyone know what this means?
  • 246 Answers
You likely have something stuck in your pump. Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on) Once you have the panel off, the white object in the front center is your pump. Remove the #20 torx screw out of there too to make life easier. Slide the pump forward
slightly so you can raise it. Now, on the front of the pump is a handle that you will need to trun counter clockwise. So after placing something under neath to catch the water left inside the machine ( a large bowl or bucket), turn the knob SLOWLY counter clock wise. If there is too much water for your container, screw it back clockwise and go empty your container. Repeat until all of the water is out. Once that is done, unscrew it all of the way and slide if forward. You will usually find missing socks, toys, coins and all other kinds of fun objects. While you have the trap out, reach in with your finger to the hole on the right. Try and turn the wheel inside to make sure there isn't anything keeping it from turning (bobby pins, nails, screws, etc) If there is, you will need to unclamp both hoses on the back of the pump and remove any further forign objects. Now re-assemble the unit but leave the panel off. Run a quick fill and drain to make sure all of your connections are tight and you don't have any leaks. Put your panel back in and you're ready to go.
Posted on Jul 01, 2008
Sorry Terry - I'm not used to this site! Question was - anyone know what the error message E34 means on an Ariston Boiler MicroGenus 24HE please?
The information I have found states it is a problem with the pressure switch. A faulty pressure switch will prevent ignition from occurring. Here is a Youtube video link showing the issue. Reading the comments below may assist you in isolating your problem. Hope this helps!
Ariston microGENUS 24 HE MFFI Error 34
Oct 21, 2015 | Washing Machines
What is error 0xc19a0003 mean for the HP Officejet 4620
ink system failure - error 0xc19a0003 means ink system failure error usually occur if you have issues with your ink cartridge or printheads. Have you try replacing either of the two?
May 12, 2014 | HP Officejet 4620 e-All-in-One Printer,...
What is this error mean that i get during boot up? 312.198 Eth0:(185488) System Error Occurred (0) 312.199 Eth0:(185489) System Error Occurred (0) 312.200 Eth0:(185490) System Error Occurred...
I think this is related to to the NIC (Ethernet port).
Go into the BIOS and set it to default settings, see if that resolves the problem.
Let me know how you get on.
Regards.
Jun 30, 2010 | MSI P4MAM2-V Motherboard
Thre is a little wrench on the left side of the screen. What do I do?
if there is an error message along with it eg. E3-10 or E2-02, recycle power, that may reset device. if not it means a service error has occured and need a technician.
Mar 17, 2010 | Panasonic Workio DP-3030 Printer
It shows 02 and f
I'm assuming this is either a Whirlpool Duet or Kenmore Elite front loader? Since you posted no brand name or model number, its hard to determine, but I do know these error codes are usually for these brand washers.
"F02" is a Long Drain error code, which usually means you have an obstruction in the drain pump, drain lines, or the drain pump has failed. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
The "SUD" error can commonly occur with this error due to the detection of air in the drain pump (lack of water flow). If cleaning the drain pump reservoir, and checking all the drain hoses does not correct the problem, you may have a failed drain pump.
Replacement pumps can be purchased on line at searspartsdirect.com, appliancepartspros.com, repairclinic.com or pcappliancerepair.com. All these sites offer competitive pricing so shop all of them for the best price.
If you have any questions about this repair please let me know. I hope this helps you.
Jul 13, 2009 | Washing Machines
Error code f 06???? anyone???
f 06 Drive Motor Tachometer Error (The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high speed spin, the door will be unlocked after 3 minutes.
* Check wire harness connections between the Drive Motor/Tachometer and the Motor control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
*Check the MCU
*Check the Wire Harness
I got this information off a website after searching for a F 02 error.
May 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
E27 Error Reset
E27 Waste ink absorber full or platen waste ink absorber full.
Download the MPTool from this site. It is a resetter utlity for the MP series printers.
http://pcprinter.blogspot.com/2008/02/mptool-multi-resetter-for-canon-mp.html
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 19, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Minolta CF900 code C3250
Description:
Intermittent C-3250, C-0210, or C-0230 codes occur during pre-drive.
Solution:
CAUSE: Worn mylar.
SOLUTION: Refers to the transfer drum joint Mylar.
SOLUTION: Replace the mylar (P/N 1144-4511-02)
hope that help
Oct 20, 2008 | Minolta EP1031/1031F CS/PRO Copier
Sony PVW-2800 Error Messages
code 02
The slack or breaking of the tape is detected in search, fforward or rewind mode, and then tape protection is done. Detected when the ratio of the FG frequency at supply reel and take-up reel is less than the specified value
Aug 18, 2008 | Sony PVW-2800 VCR
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
52 people viewed this question
Sal De
fordexpert
Robert Rankin
