Question about Kenmore 15864/15862 Top Load Washer
Kensmore 70 series
Would not spin, repaced coupler, spins slowly making loud clanking noise
  • mortski Sep 23, 2008
    Replaced the supension springs, and now it "clanks" when in rinse cycle, then later the agitator moves really slow in the rinse cycle
  • 550 Answers
Often times, the coupling is not fitted completely, and the excess pressure is binding the motor or gearbox up
Not a guaranteed solution, but something to check
reopen the case and motor, and use a dowel and hammer to ensure the spiders are fully pressed onto the gearbox and motor shafts
Posted on Aug 19, 2008
I have a Kenmore 70 series top load washer which will not go into the spin cycle. It is making a loud clicking noise
lean the washer back and look between the motor and trans,there is a coupler in the middle that most likey broke
May 04, 2010 | Kenmore Washing Machines
I have a Kenmore series 70 washer that stopped working and when I turn it on it makes a loud clicking noise. Any suggestions on what this might be. Thanks!!
This is most likely a motor coupler. Set to spin see if it drains... If it drains then it is the motor coupler.
I hope this helps...If I can do anything else to help please let me know.
Mar 20, 2010 | Kenmore Washing Machines
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore top load washer making loud noise in spin
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 02, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Mar 10, 2009 | Washing Machines
Kenmore 70 series will not drain or spin
It sounds like the lid switch. If it ws the coupler the water would drain. Check to see if the lid switch is clicking when you put the lid down. replace the lid switch. You have a great washer. Fairly cheap fix.
Nov 20, 2008 | Kenmore 20722
Kenmore Washing Machine 70 series
When this machine is not spinning, the water should still be able to drain, as the motor drives the pump on the same shaft as the coupler for the tranny. Set to the spin setting and depress the lid switch, if the water still does not drain, you may have something stuck in your pump, which would also lock the motor shaft and not allow it to spin or agitate. If the water does drain, check the motor coupler, which is located between the motor and transmission, if broken, the motor will run but there is no drive to the transmission. Hope this helps...
Sep 14, 2008 | Kenmore 20722
I have a kenmore 70 series washer,the machine won't spin. I hear the clutch but it's not engaging. The pump to remove the water seems to be operating but the tub just won't spin and makes a loud noise.
The loud noise (sounds like rattling or grinding) is the motor coupler. It's between the motor and the transmission. This part takes the place of the belt, and costs about $20.00.
Mar 31, 2008 | Washing Machines
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
65 people viewed this question
Sal De
fordexpert
Robert Rankin
