Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Get a Professional
Find a Solution
Most Common Problems for:
Kenmore 54501 Dehumidifier
clfort on Jun 30, 2008
We have used a drain hose for a few years that drains the humidifier into our sump pump. All of a sudden the bucket fills up instead of the water draining through the hose. What do I do?
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Jul 23, 2008
-   same exact problem
-   toconnor2
Solution #1
posted on Aug 12, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Clean the hose (it's full of black gunk)
Related Problems
makinga chirping sound does not produce any condensate....
The dehumidifier turns on and it sounds normal. But water is...
during hi humidity the unit runs but does not collect water...
Unit runs OK but the coil fins are filling up with ice and...
Can you Help with these Dehumidifier problems?
53650 Runs for < a minute...
Solve
I have a similar problem with Model 53650. after about 2 years of summer use it now has this... (More)
My Kenmore 54501 dehumidifier works...
Solve
My Kenmore 54501 dehumidifier works for a couple of minutes, shuts off for about 10 and then back on... (More)
i have a hampton bay bhdh4000as2...
Solve
i have a hampton bay bhdh4000as2 dehumidifier. the fan turns on, but the compressor does not. Please... (More)
the humidifier runs but no water is...
Solve
the humidifier runs but no water is in the bucket
dehumdifier problem
Solve
the dehumidifier runs fine but it does'nt produce any water in the container,no matter what humidity... (More)
Sponsored Links
Describe your Appliance problem:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
