Question about Bosch Dishwashers
Bosch Slimline Classixx,water cutting on/off during filling on any program, have changed inlet valve already, made no difference
    Novelist:
  • 161 Answers
Does it still have enough water to wash? Mine does this too. The float is very sensitive. If it gets the dishes clean don't worry about it.
Posted on Jul 03, 2008
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
My Bosch classixx washing machine is overflowing
Bad water pressure switch or bad water inlet valve? does it have or leak water in the tub when not in use? ( inlet valve) sometimes the pressure switch tube has a hole or blockage in it and will not have the pressure needed to open diaphram and go into wash cycle and it may overflow
Mar 09, 2015 | Bosch Washing Machines
Bosch classixx washing machine over fills, stops for 5 mins,drains water and stuck on rinse without doing the wash cycle. it spins when spin cycle is manually selected.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 25, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Unit won't fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not filling with water. Humming noise.
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Jan 08, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher will not run or fill with water. check water light comes on
Possible that the inlet valve is not working . check the voltage of the inlet valve when the program is put ON. If there is voltage with no water flow the valve is faulty if not the program controller is having errors and must be checked out.
Sep 24, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have a bosch classixx slimline dishwasher when I use the quick wash the tablet doesn't dissolve. Is ther any solution to this problem
Check your inlet water flow to the machine. Clean the filter at the machine end near the flexible hose connection!
Sep 15, 2010 | Bosch Dishwashers
Bosch Classixx 1200 red wash light flashes but doesn't start
Could still be the water inlet valve. What you need to do is pull the washer out where you can get to the valve and the plug. Unplug the inlet valve and start the washer and when you start it as normal check the volts of the plug and see if its 110 if it is you know that the valve is getting power to open but not,replace the valve. If you dont get any voltage then it could be the relay or control board
Sep 02, 2009 | Bosch Classixx WFL 2066 Front Load Washer
The check water sign is on when machine is turned on
Hi there.....check water pressure going to inlet water valve.......if this is ok.....isolate water....remove inlet fill hose and check if filter in inlet valve is blocked....also check if you got filter in inlet hose
regards Sir Galahad
Aug 20, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Water inlet not filling
check it has drained completely after the last cycle.
if that is ok, take top off and check continuity thro the inlet valve coils
Aug 21, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Dishwashers Logo
136 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
