My Calypso washer has FL as an error code... it's not flooded, it just stopped working in the middle of the wash cycle
  • deedeeg Aug 17, 2008
    I keep getting the FL error on my display screen. It is not flooding. How do i fix
    Genius:
  • 1,028 Answers
Pump may not be working or stopped up control actually senses a overfill
Posted on Jul 01, 2008
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Error code FL flashes and my calypso washer keeps beeping. Won't start just shows the code.
FL error - Flood condition
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
You coudl se this manual: Service_Manual_PDF
Hope this helps.
May 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso washer will not work, the flashing light says FL ? Can you help
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 20, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
WHAT DOES FL MEAN AND HOW DO I FIX MY WASHER WHEN
Flood Condition:
Jul 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code constantly flashes, how do I reset?
Flood Condition:
May 23, 2009 | Kenmore Washing Machines
My calypso stoped and FL flashes and will not cancel,
Flood Condition:
Feb 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL error on my Whirlpool washer
Flood Condition:
Dec 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Getting ''FL'' error code w/Whirlpool Calypso
you can try unplugging the washer and letting it reset the system. thenplug it inand press the spin/drain button. if it still gives you the flood condition chances are the pump is faulty and needs to be replaced. it may be covered under whirlpools warranty for the law suite against the washer. otherwise you can get the pump off ebay for cheep and install it yourself. its just a little messy so if you do it yourself make sure you have a shop vac around to **** up the excesswater.
Nov 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
I have a whrilpool calypso washer flashing the fl code
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^$#@
Nov 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
