Question about Lite On LVW-5005 DVD Recorder
Hard reset I have already disconnected the power several times and I even let it set disconnected over night. The only response I get when starting is "Hello" and nothing else happens
  • 1 more comment
  • grcarter5 Jun 30, 2008
    No,
    Is there a reset button or something on the machine, similar to rebooting a computer?
  • grcarter5 Jul 02, 2008
    do you have something that is not common sense? I am fairly tech savvy and I would like something more concrete
    Guru:
  • 1,894 Answers
Ok fine. is there any damaged disk inside this unit?
Posted on Jun 30, 2008
Locate airbag sensor
Many are mounted to the floor board under center counsel between front seats. If your airbag has been tripped you must replaces this module. They're hard to order new but I've had good success reusing from junk yard cars that haven't had bag deployed. Warning do not mess with airbag system until battery has been disconnected for at least 2 hours. I disconnect over night. These modules hold a charge with capacitors so it can activate in an accident even if battery cable is severed before bags are deployed. You must give capacitors time to discharge on their own or risk setting off the airbag by working with this system to soon. Of course this warning is only for working on systems that haven't already been set off or deployed. ie when reassembling system.
Sep 14, 2014 | Cars & Trucks
Tip
How To Fix Your G1 Stuck On The Android Logo
First, if you haven't already tried it, please remove and re-insert the battery.<br /><br /><b>The following method erases all data from the handset's memory, and sets it back to original factory settings. It does not erase the sim card or the memory card. </b><br /><br />There are two ways to perform a Factory Data Reset, also known as a master reset or hard reset. Since we cannot boot into the device, we will perform a hard reset:<br /> <ol> <li>The device must be powered OFF to perform this reset.<br /><b>Note: </b>If the device is not responsive and does not turn off, remove the battery and re-insert it. </li> <li>Press and hold the <b>Home</b> button (picture of a house on it) and the <b>Power</b> button (the red hang-up button) at the same time.</li> <li>Keep holding <b>Home </b>and <b>Power </b>together for at least 25 seconds, even if the "Startup" screen appears.</li> <li>Release the keys when you see a black screen with a warning sign.<br /></li> <li>Slide the keyboard open.</li> <li>As a shortcut, press <b>ALT+W</b> to factory reset the device. If this does not work, continue with the below steps.</li> <li>Press <b>ALT+L</b>.<br /></li> <li>Press <b>Alt+W</b> for 'wipe data/factory reset'.</li> <li>Press the <b>Home</b> + <b>Back</b> key.<br /></li></ol>
on Jan 25, 2011 | Cell Phones
Where is the airbag sensor for the fender on a 95 monte carlo
The sensor consists of a sensing element, normally open switch contacts and a diagnostic resistor. The sensing element closes the switch contacts when the vehicle velocity changes are severe enough to warrant air bag deployment. They are located around the bumpers near the fenders. Look on the framing near the fender. I attached a picture of one.
May 27, 2014 | 1995 Chevrolet Monte Carlo
Not able to turn it on. for no apparent reason the screen was black after setting overnight. The pilot light was on. tapped the space bar a couple of times thinking the computer would wake up and desk top...
I have the same monitor & just had same problem. Did you find a solution to your problem? This is the second time my monitor has done this. The first time I had problem i unplugged it and disconnected it from pc. Plugged it into power source and blue pilot light came on then went off. I did see the LG logo on screen before it shut down. After several times doing this and pressing the power switch repeatedly it seemed to reset and recognized it was not receiving a signal and indicated this. I then reconnected monitor to pc and all appeared to work fine for several days. Now I again have same problem after sitting over night.
Dec 02, 2009 | LG W2252TQ Monitor
No power When I press power button.- Battery is full
Try changing ur battery if it doesnt help then do this
try pressing the reset button near the charging port on the pda if it doesnt work try to hard reset it as follows
try this if it helps
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest Rom update downlaod and update
other wise check xda forums for software dead HTC http://forum.xda-developers.com/
pls do rate me if i fixed ur problem
Feb 24, 2009 | HTC Touch P3450 Smartphone
Ibook G3 will not start
If you stilll have the Mac OS installation CD available the when it is starting up press down C and it will start from the Mac OS X installation Set up then you can reinstall OS X and it should work.
Apr 17, 2008 | Computers & Internet
Loud, screeching noise when taking a message
Managed to clear it myself. After making several cell phone calls to my machine last night and unplugging it over and over, etc. I gave up. This morning I again unplugged everything, reset all the settings and called the machine several times. At first I kept getting the "noise", but eventually I was able to call and leave a normal sounding message. Can't really explain what "cured" it! In desparation I did shake the machine and give it a hard slap, but who knows what did it!
Apr 05, 2008 | GE 29875GE Digital Answering Machine
Trinitron KV-36FS13
The problem is in the standby power section. Check the fuse, R607, or burnt IC601, fuse R612 and VD relay 601 should show open. Its possible it could be the high voltage area of the power supply. You can try unplugging the set and cable and let it sit 4 to 6 hours. This is a hard reset. If it still doesn't turn on after the hard reset and the fuses and relays are fine, and you don't smell anything or see anything burnt. Then you'll need to call a TV repair man. They normal start around $150-$200 to fix the set. I hope this helps.
Jul 10, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Lite On LVW-5005 DVD Recorder Logo
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
