Question about Sharp AL 1631 Copier
Top paper feed jams
The top paper feed jams half way through....if I lift the right corner and minipulate (wiggle) the bar the motor / rollers crank back up and complete the cycle. I've cleaned the parts....shook out a staple but still no luck... do I have a Position Switch Problem???
  • Tim Babcock
    Tim Babcock May 11, 2010
    Where in the copier is it jamming at?
  • 29 Answers
If your feeder is jamming you need the roller & pad replaced and usaaly the internal feed roller cleaned this is a repair that should be done by a sharp tech about a $150
Posted on Mar 10, 2009
Will not feed paper. Can print with manual feed in center of printer, but will not pick up paper in tray. It tries three times and can hear the motors whirring, but then stops trying and the attention...
When you look into the tray with the flashlight, you say the top rollers are spinning, are they touching the paper?
Pull open the tray and while you look from the back with the light, close the tray and see if the paper is being lifted to meet that top roller. Take out all the paper and watch it again. Make sure that the platform that the paper sits on in the tray is free to move up. Sounds like it is jammed.
Also check that roller that isn't spinning. Try to GENTLY rotate it with your fingers. If it does rotate, replace the tray. If the paper in the tray doesn't lift, replace the tray.
Oct 30, 2010 | HP LaserJet 1320 Printer
Paper does not feed through, gets crumpled, jams
you have to remove all covers, then you have to clean all paper feed rollers..chek fuser assy too! If you unable to do that just go visit any special printer service!
Apr 05, 2010 | HP LaserJet IIIp Printer
Paper feed jamms the paper all the time, will not feed without jamming from bottom tray, top tray jams every 2 to 3 prints or print with the top corner bent
Unless both feeder rollers went bad at the same time, which is unlikely, it must have something to do with the paper. It might be slightly damp, or not the correct kind. Try using high quality matte white paper from a brand new pack and see whether it still jams.
Oct 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
False ricoh 1224c paper jam warning
check tthe clips retaining teh feed rollers havent sliped off if it isnt picking up from tray take the tray at top out and then watch from above to see if the rollers are turning to feed paper.. if the lifts out check the side door guide isnt out of plavce check the end paper guides as well//check when you take the tray out look to see there is any paper stuck at the back where the tray sensors ares can cause a lift motor error aswell
Mar 24, 2009 | Ricoh Office Equipment & Supplies
Hp laserjet 8150 printer jams from tray 3
Check the rollers in tray 3 to see if they are slick. If not, replace the paper input unit C4214-69017.
Feb 19, 2009 | HP LaserJet 8150dn Printer
Paper doesn't feed
It could be a few things, but the times I've had similar problems it was either caused by the feed/gripper rollers in the paper trays being worn out, thus not feeding any paper or feeding half a sheet and then jamming.
Or, it could be that the elevator in your paper tray isn't lifting, but if it's taking paper it's probably the rollers.
Jan 12, 2009 | Canon Office Equipment & Supplies
NP6050 false paper jam
Can you see the paper pick-up rollers try to move and pick-up the paper? Or can you hear it make noise? Also, is the problem in paper tray 1? You may have to adjust or reform a inter lock arm on the right side door. If you push the back part of the right top door closer, will it feed the paper? If so there is adjustments for the door and look for a bent Tab on the hing part of the top door about half way up. Just a note have the paper pick-up & paper feed and paper sep rollers been replaced?
Dec 15, 2008 | Canon NP 6050 Copier
Paper Feed errors on 2400W
It is a timing issue, mine does the same thing. Here is fix. Open top door, remove drum cartridge, look inside for pickup roller ( the one that is shaped like a half-moon) reach down there and rotate it towards the front of the printer and downward so the curve ends up being pointed down to the bottom of the printer. You should here a loud click, that is the cam being reset. The cam is to the left behind the 2 gears. remove any paper feed jam, reinstall drum and close the top lid. This should reset it back correctly. Do the above steps with paper in tray and the power left on. Do not reset the printer after resetting cam position. Also it might take a few attempts to get the timing reset right, so dont give up after 1 failed attempt. I have had to do it 10 times before to get the timing right. Just make sure the curved area points downward.
Sep 27, 2008 | Konica Minolta magicolor 2400 Laser...
Sharp AL 1631 Copier Logo
95 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
