The fan in my Heil air conditioning unit runs for a while then stops turning. When I turn it off for a while and re-start it it runs. Is there a way to lubricate the fan. The motor is running but the fan stops.
    Novelist:
    Champion:
  • 230 Answers
It is stopping because it is over heating. You will need a new one. Most of the electric motors today do not need lubricating.
Posted on Jun 30, 2008
I have a 1989 heil air conditioner, fan suddenly stop working, replaced capacitor A/C worked for 1 day and stop again.
It is possible that the replacement capacitor failed or some other condition not related to the capacitor caused failure.
Jul 08, 2016 | Heating & Cooling
Why is my heil Air exchanger fan not blowing
Sounds like you may have a bade blower motor.
Aug 17, 2014 | Heating & Cooling
Heil epm36f19a1 runs but no heat
Fan relay is stuck among other things. The thermostat turns on the combustion air fan and puts power to the spark unit. If the burner comes on after the temperature in the heat exchanger rises the indoor fan will then come on. After the thermostat comes to temperature the power to the gas valve which shuts off the burner. Then after the heat exchanger cools a bit the indoor fan will stop. That's the sequence of events. look at the switches that control the fans. There is a wiring diagram somewhere on one of the panels that access the unit for service.
Mar 06, 2013 | Electronics - Others
My ac central air is blowing air but not cold
Problem #1:Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device known as a "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning compressor. Another good device is called a "5-2-1" kit.
Jun 22, 2011 | Goodman CKL36AR36 Air Conditioner
My air conditioner tries to turn on, air comes out of vents but isn't cold, and outside the blades on the AC unit are not spinning. I hear a noise when it tries to turn on but they don't start...
Jun 17, 2011 | Heating & Cooling
We have Goodman AC unit...not sure what kind. It has blown VERY cold until the last few days where it would stay a little above where I had it set. Then yesterday I realized it was incredibly hot. My...
If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning systems.
Jun 11, 2011 | Heating & Cooling
My lancer 2004 when I start the the engne the fan is running right away even the radiator is still cold and when the engine is turned of the fan is still running for aobut 3 to 5 seconds before it finally...
engine thermostat is a triggering devise to make the fan's work. seconds before it stop when the engine is off, normal for the engine high temperature but it's sign abnormality in the system. fans also runs when the air conditioning unit is "on" to keep the engine operating temperature for its additional load from the unit. need to check if the air conditioning is in "on" position, especially the engine thermostat it may be stuck.
Mar 01, 2011 | 2004 Mitsubishi Lancer
The outside unit is not working on my Heil Air conditioner
The attic fan is not a part of your a/c system, and you should not run it while you are running the a/c. If you are currently using the attic fan, it is possible that someone wired it so that the a/c won't turn on while the attic fan is on. Otherwise if the thermostat is set below room temp, and says it is calling for cool, then the problem is most likely coming from an issue at the outside unit itself. Make sure to check your fuses, at the fuse panel and outside breaker. Hope this helps
FYI.. the only part of the system that might use batteries is the thermostat.
Jul 28, 2009 | Heating & Cooling
Heil 9000 Air Conditioning Unit problem. . .
It could be the fuse in the disconnect box are no good.
Apr 23, 2009 | GE AJCH10ACB Built-In Room Air Cool Unit
Heating & Cooling Logo
148 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
