Question about Whirlpool Heating & Cooling
Portable air conditioner runs but the compressor never kicksin. unit does not cool.
    Novelist:
    Champion:
  • 230 Answers
I believe that the capacitor is bad. Sometimes your local graingers or other supply house will carry these. It should be tested with a MFD UFD capable meter before you try to replace it. Be warned that this capacitor can deliver a big jolt. It may be best to call in a professional
Posted on Jun 30, 2008
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
Why is our a/c blowing room temp air when the setting is on cool?
It sounds like the compressor is not running. This could be due to a faulty thermostat, a bad start capacitor for the compressor, a bad compressor overload or simply a bad compressor. You would need a voltage meter to check all of these components.
Jun 20, 2014 | Maytag Portable Air Conditioner M6P09S2A
My portable. Air conditioner. Isn't cooling
Could be a number of things, Is the compressor running? If so, are the filters clean? ( Both the outlet and the inlet filters.) One at the front where the air comes out and one at the back where the air goes in.
Sep 07, 2013 | Portable Air Conditioners Portable Cooling...
Portable ac
Is the compressor running? Normally the fan starts first then the compressor. You should hear it start. New units could take up two minutes. If you hear the compressor start and no cooling you have lost the refrigerant or a bad compressor.
Jun 30, 2013 | Heating & Cooling
Compressor wont start..blows hot air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | LG LP1200DXR Portable Air Conditioner
Botton of evaporator coil freezes and compressor
This is a common problem with any type air conditioner it is caused by to much humidity in the air when the unit is not big enough to Handel the cooling I would suggest getting a bigger unit, adding another unit or a dehumidifier, or setting the unit to a higher temp. then turning it down gradually to let the ice melt and take the humidity out gradually.
Jun 27, 2009 | Ambiance Designs HG002261 Portable Air...
My CV-13NH portable type room air conditioner won't blow cool air
If its blowing air, but not cold, the compressor isn't engaging. There are many different possibilities on this.
Bad compressor, unit out of gas, bad run capacitor, etc, all could cause this, even a bad control panel.
Hope its something simple.
Greg.
Aug 18, 2008 | Sharp Heating & Cooling
No cooling
May have burnt wire or bad capacitor to compressor.When running incool can you here the compressor running or is it maybe just the fan outside running?
Jan 08, 2008 | Fujitronic FH-797 Portable Air Conditioner
Heating & Cooling Logo
46 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
