Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Need to find Main PCB part #E7801-043006
Our tv began flashing and we had Circuit City tech come out & he told us we need a new Main PCB which is their part # E 7801-043006 (not sure how he figured that out because he didn't even take it apart). I am trying to find some type of cross reference to this part so we can order it. They want $1200 for the part & install from Circuit City and I've only been able to find that exact part # on one other site which is no longer avail and they don't have any other info on it. Any info you can offer will be much appreciated! Thank you!
My suggestion is to send the board to a company called PTS Electronics. They will fix the board and send it back to you.
If you can't remove the board itself send the chassis to them
Posted on Sep 11, 2008
    Champion:
  • 217 Answers
Yuo should'nt have to pay more than 350-400
Posted on Aug 03, 2008
I am seeking a circuit or service manual for a LA40A450C1DXXY
We tried to turn on tv and it will not show a picture or sound can you tell me what is wrong with it
Jul 10, 2013 | Televison & Video
La40a450c1dxxy service manual
i have been told that my power suppy board has gone out and i need to know how to fix it and where it is
White flashing on netflix with hdmi cord
This happens with all three? You have a bad HDMI circuit in your TV. The Main pcb, will need to be replaced.
Apr 19, 2012 | Sceptre X320PVFHD 32 in LCD TV
My tv wont turn on. The red light keeps flashing. Have I set the timer or something?
the reason the tv flashes its l.e.d is to tell you there is a major fault in the main circuit board (pcb) and needs to be fixed its not a fuse it not a reset problem its a dynamic fault that could be from a bad resistor to a downed capacitor if you have knowledge of these components then check them using a multimeter find the faulty parts and replace accordingly. but if you have no idea then it will need to go into the repair shop. a lot of our customers ask us if the unit (tv) etc after being fixed will be any good or should they buy a new one. a good tech will fix the unit and in most cases it will be tweeked and work better but always get a quote up front and hold them to it within $50.00
best of luck to you
if you need further advice please feel free to email us at sonicboomelectronics@hotmail.com
merry christmas
please take the time to rank this advice if it helped you.
Dec 22, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
DLP TV starts to loose picture after 1 - 1/2 hours of use
This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
Nov 22, 2008 | Samsung HLN5065W 50" Rear Projection...
Same problem as others. Sony KDF-E55A20-while watching TV, screen goes black and sound leaves too! Will come back on in a few seconds...but continues this cycle. The green light stays on.
You really need a tech to check the error codes recorded in the TV to be sure. You could have a bad lamp driver, but I would want to see if any error codes were recorded
Sep 25, 2008 | Sony KDF-E55A20 55 in. LCD Television
Philips 42PF7320A/37
a 7 bliink error for this model is an 8.6 volt error normally caused by the y main overloading the power supply. disconnect the y main from the power supply and if the tv starts up check primary voltages per power supply sticker on pdp and if correct replace y main and y upper and lower buffer boards as they work together as circuit
Aug 14, 2008 | Philips 42PF9630A 42 in. Plasma Television
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Th-42pz700u
I have a similar problem.  It turns on ok, but after an hour, if I turn it off and try to power up again I get 10 flashing red lights.  Must unplug and wait to cool down to room temp - then it works.
Had the H-PCB and DG-PCB replaced and still no luck.
I am exchanging for another one.  The service guys want to take it with them, but would provide a loaner.  Need to return this within the next two weeks to get an exchange...
Oct 13, 2007 | Panasonic TH-42PZ700U 42 in. Plasma...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
53 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
