Question about Canon PIXMA MX310 All-In-One Printer
Report of fax
Help me to receive a  singular report when I send a fax
  • Anonymous Mar 20, 2014
    Turn off the transmission report on received faxes.
  • 667 Answers
Hey renzo737 - Follow these steps to have your machine print a report after you send each fax:
1)Hit the Fax button, then the Menu button.
2)Press the < and > buttons to scroll until you reach
TX Settings. Hit OK.
3)Use the < and > buttons to scroll until you reach TX REPORT.
Then hit ok.
4)First you want ATTACH TX IMAGE and then you want
PRNT FOR EACH TX.(it may also say as TX REPORT)
On your machine under TX report it may just say PRINT ERROR ONLY, which means only print if there's an error, or the PRNT FOR EACH TX. You'll find it easily. You want the print for each tx option. This will print a report and give confirmation that your fax went through after each fax. If you have any problems understandind this or need more help just give a shout.
If this solves your problem PLEASE rate this as fixed. Like I said if you need more help just add a comment and I'll be happy to assist you further. Thanks and have a good one.
Jeff
Posted on Jul 01, 2008
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
How do i set up the fax to print a confirmation sheet when it sends something?
Try this:
Press the Setup button (it might be the sign of a monkey range)
  1. Press the Down arrow (c00844971.gif ) to highlight Print Report , then press OK .
  2. Press the Down arrow (c00844971.gif ) to highlight Fax Confirmation , then press OK .
  3. Press the Down arrow (c00844971.gif ) to select one of the following options in the table below, then press OK
On Fax Send Prints a fax confirmation report for every fax you send. On Fax Receive Prints a fax confirmation report for every fax you receive. Send and Receive Prints a fax confirmation report for every fax you send and receive. Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
Select the one you would like to choose ;
For further help click on the following Link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01083680&cc=us&lc=en&dlc=en&product=3204785
Regards Soumajit
Sep 21, 2009 | HP Photosmart C7280 Laser Printer
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
1. Press Setup.
Send &
Receive
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Canon MX 300
I cant send Fax. I also receive a message ''waiting for report''and"memory receive mode". Please Help
Sep 17, 2008 | Canon MX300 Office All-In-One Printer
How do i retrieve fax report from hp 4215 all in one
1 Press Setup.
2 Press 1, then press 1.
This selects Print Report and then selects Automatic Reports Setup.
3 Press ! to scroll through the following report types:
– Every Error: prints whenever there is any kind of fax error (default).
– Send Error: prints whenever there is a transmission error.
– Receive Error: prints whenever there is a receiving error.
– Every Fax: confirms every time a fax is sent or received.
– Send Only: prints every time a fax is sent.
– Off: does not print fax reports.
Note: If you select Send Only, you will also receive error reports if there is
any kind of error generated.
4 Press OK to select a report
More information? you can download manual here
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
Sep 05, 2008 | HP Officejet 4215v All-in-One Printer
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
361 people viewed this question
old marine
old marine
