Question about Nikon COOLPIX S5 Digital Camera
Nikon trouble shooting
I have a Nikon 6.0 I think and it keeps sending my pix to the internal memory how do I get the pictures sent to my disk?
I was downloading pictures from my nikon d40 to my pc and accidentally disconnected the USB cord.
Now it wont turn on, what can i do to make it work again.
Posted on Sep 28, 2008
After downloading my pictures onto the internet i accidently disconnected the usb. now its not turning on what can i do to make it work again
Tip
Nikon Coolpix keep resetting Time and Date and menu settings.
Hi.
I am listing this tip for the Nikon Coolpix 995, but the tip is valid for all Nikon Coolpix models.
The Nikon cool pix settings are saved into an internal memory.
The internal memory is maintained by an internal rechargeable battery, that is recharged from the main Li-Ion battery.
If you leave your Nikon overnight with no main battery, or if the Li-Ion batteries have drained, then the internal battery will also drain , resetting the clock and other settings, saved on the internal memory. The camera may even drain in about 6 hours depending on the camera, normally it takes at least 12 hrs to drain the clock battery.
If the internal battery is resetting immediately, after you set the clock, or just after few minutes, then the clock battery must be replaced.
The camera must be disassembled completely to replace the battery located on one of the two main internal boards.
Nikon says that the clock battery loosing charge is normal. I quote what they say on the publication titled " The Nikon Guide to digital photography with Coolpix"
"Backup battery of the clock
The clock-calendar is powered by a separate rechargeable battery, which is charged as necessary when the main battery is installed. If the camera has been stored with the main battery removed for a long period of time, the clock may need to be reset. Once the main battery has been reinserted, the clock battery will recharge in several hours, during which time the main battery should be left in the camera."
Original file: Download here
If the clock does not work at all, and is resetting immediately, even though the Li-Ion batteries are fully charged, then the best thing to do is calling Nikon, at the number listed on the owners manual, telling them that you did not do any improper use of the camera, and trying to get the fault repaired as factory defect. That is not always possible, and the decision depends on Nikon customer service.
See also: Nikon | Contacts
Ginko.
on Feb 05, 2010 | Nikon Coolpix 995 Digital Camera
Out of internal memory on nikon coolpix s9100
Please set the camera to the smallest possible setting so you can take more pictures. The internal memory of your camera is only 78MB.
Sep 03, 2012 | Nikon COOLPIX Cameras
I purchased a Nikon Cool Pix Camera in December 2009. In April, I was unable to take pictures for some unexplained reason. I took the camera into Best Buy to have the Geek Squad look at it. They told me...
You have not heard anything from FixYa because Nikon does not tell us who has sent in cameras for service. Please contact Nikon directly. FixYa has no better pipeline to Nikon than have you.
http://support.nikonusa.com/app/answers/detail/a_id/238
Nov 09, 2010 | Nikon Cameras
How do we get images that are on the camera memory not the sd card off the camera. We tried via nikon transfer to the computer and the computer doesn't see them, but it says there are 196 pix
To copy pictures to/from the internal memory, select Copy from the Setup menu. If you want to transfer them to a computer, remove the memory card before making the connection.
Feb 10, 2010 | Nikon Coolpix L11 Digital Camera
Picture on viewer fine..transfer to computer divided
It sounds like the file is corrupted. Try formatting the memory card in the camera. This will wipe the memory card clean and eliminate it from the being the problem. Formatting the memory is erase the memory card and you willnot be able to get the pictures off it after you format it, so make sure you down load all you the pictures you want befor formatting the card. Then occasionallly after downloading everything, format the card on a regular basis. This will help to keep the cards internal memeory from being fragmented. If formatting does not fix the problem, try another card (format it before use) if this does not fix it, take it to a local camera store and let them trouble shoot the problem or send the camera off for repair.
Nov 21, 2009 | Nikon D60 Digital Camera
Nikon D80, how do you turn off the r09, r11 and/or r17 alert (depending which Image Quality setting I have the camera set to)? I have sent the camera back to Nikon twice and twice it has come back with the...
The r09, r11 or r17 just tells you how many pictures you can shoot before the internal memory buffer is full. It's not an error message, and I don't think there's any way to turn it off.
Sep 29, 2009 | Nikon D80 Digital Camera with 18-135mm...
My Nikon Cool pix P3 says out of memory IN after 12 pictures
check the battery condition, Nikons have a trnd to lock up if the battery is low or about to die
Nov 16, 2008 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix 5400 lines in pix
Yes! Send the camera to Nikon with the service form. It takes about 3 weeks, free of charge.
Nov 05, 2008 | Nikon Coolpix 5400 Digital Camera
Nikon Coolpix L4 Memory card problem
Back up all the pictures on the card and then format the card.. Everything will be back to normal.
Note: While formatting select FAT32 file system as it is more reliable..
Jun 18, 2008 | Nikon COOLPIX L4 Digital Camera
Nikon COOLPIX S5 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
