Question about Samsung (SP0411N) 40 GB Hard Drive
Hard disk data recovery from a bad sector
I bought a hard disk with 200 GB capacity, and tried to back up my old Samsung SP0411N.
While carrying it to connect it to another pc with the new hard disk, it accidentally fell from my hand. :~/
It had 6 partitions (C:/, D:/, E:/, F:/, G:/, H:/).
When I connected it, drive G: was all wiped out, which was okay.
C:/, D:/, E:/ and F:/ were all working.
And the H:/ drive was erased partially.
I absolutely NEED the lost data in the H:/ drive.
Is it possible for me to maybe map the data in the bad sectors of H:/ drive to another working partition?
Or to recover the data in any way, with a software if required?
Please help me.
I'll be grateful for any help.
  • nes_22654 Jul 21, 2008
    the same
    Please help me.
  • 734 Answers
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Posted on Dec 12, 2008
I bought a brand new samsung s2 320 gb external hard drive and use it for several months until consuming about 200 gb of its storage space, I started to have problems in accessing my data. I tried several...
Only store file on the drive not programs. Working program cause to much ware and tare on the external drives.And a partition on a driver that has programs running from it works real hard because it moving file from two sectors of the drive at the same time. Can you be in two places at the same time?
Feb 06, 2011 | Samsung S2 - 1TB USB 2.0 Portable...
When I was trying to boot the system the following error is getting flashed on my screen and asking me to press F4 to continue. pri master hard disk: S.M.A.R.T. command failed
this is a warning your hard drive is about to fail
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Dec 01, 2010 | Samsung (SP0411N) 40 GB Hard Drive
How to clean bad sector
Open My computer, right click drive and select properties, click the tools tab. Now select error checking check now. Select both options (auto fix and Attempt recovery) The check will be done on next reboot. You will get a report as to errors and weather they were able to be fixed.
Dec 05, 2009 | Samsung (SP0411N) 40 GB Hard Drive
Remove the bad sector from samsung sp0411n
Although A format could help it sounds more like you have some bad sectors on the harddrive.
Right click on the drive, select properties, then select the tools menu and initiate a disk check. it will give you an option screen before it proceeds, select the option to scan for a recover bad sectors/clusters. This will write off and mark the bad sectors so they will not be used again. If the problem comes back again soon then your palette media is failing and you should replace the drive.
Good luck and let us know how you make out,
Chris
Jun 03, 2009 | Samsung (SP0411N) 40 GB Hard Drive
My sp0411n my hard disk of capacity 40gb it is showing 5gb space my know reason why it is showing 5 gb space
hi first off what OS (operating system) is installed. Did you install that OS?
If the answer is yes ,did you format and partition your hdd or did you format and create separate partitions and left atleast 30 gb unpartition
Feb 27, 2009 | Samsung (SP0411N) 40 GB Hard Drive
Samsung 40 GB Spin Point Hard Drive problem
try to use some Hard drive recovery programes or try Paragon partition manager.
Sep 29, 2008 | Samsung (SP0411N) 40 GB Hard Drive
16 bad sector
Scandisk(or whatever) should mark those sectors as bad, thus preventing them from being used. But no, you cannot erase them, they are physical areas of your disk that cannot properly hold data. Bad sectors are not uncommon, and nothing to be alarmed about, but a loud hard drive is...
Mar 01, 2008 | Seagate (9W2892-337) 80 GB Hard Drive
SAMSUNG IDE HDD SP0411N (40GB)
Three possible reasons:
1. Your IDE cable is defective or is not seated/plug in correctly. Try to replace or re-seat/re-insert;
2. The on-board disk management of the hard disk is corrupted/defective. There is no remedy except to replace the PCboard or the entire hard disk;
3. Your motherboard BIOS/CMOS needs to be flashed and/or something is wrong with the IDE interface.
Of the 3, # 1 is the most common.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Jan 06, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Samsung (SP0411N) 40 GB Hard Drive Logo
178 people viewed this question
Top Samsung Computers & Internet Experts
Brian Sullivan
Brian Sullivan
PrintDocta
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
