My hp psc2100 has got into French mode and the handbook page 35 asks that one presses a black square whic is not apparent on the front panel
I played for 10 minutes with the 'Set-up' and 'Enter' buttons and suddenly found I was seing English.
Posted on Jul 01, 2008
Cartridges won't align
The HP printer can perform an print cartridge cleaning procedure even after the alignment message has displayed. Follow these steps to perform an print cartridge cleaning procedure at the front panel:
1.On the front panel, press the Menu or Setup button (depending on the model).
1.Press the right arrow button (>) until Maintenance or Tools is displayed, and then press the OK or Enter button (depending on the model).
1.The Clean Print Cartridges message should display on the front panel. Press Enter or OK to begin the cartridge cleaning process.
A page will be printed during the cleaning process with all of the colors on it. If any of the colors (including black) are missing, faded, or streaked on the alignment page, there is a ink cartridge problem.
If you go to HP website you can find more detailed information about alignment. Here is the link.
Dec 07, 2010 | HP PSC 950 All-In-One InkJet Printer
Toshiba 23HLV87 HDTV
Please try to unplug the TV from the wall outlet and then rest it for a while pulg it again and test. if still the issues remain then try to see the all the switch menu infront of the TV maybe lock or got errors.
melnavz
Jul 23, 2008 | Toshiba 23HLV87 23 in. LCD Television
Black cartridge is new,magenta is new blue is halfway and yellow is halfway but the hp color laser jet 2600n prints lighter and black prints as it is finished
Hi Good day!!
Follow this method hope it helps you!!
During the printing process, paper, toner and dust particles can accumulate inside the printer. Over time, this buildup can cause print-quality problems such as toner specks or smearing. This printer has a cleaning mode that can correct and prevent these types of problems.
This printer has two processes for generating cleaning pages: one is automatically generated and one is manually generated. When a new black print cartridge is installed, a cleaning page will be automatically generated prior to calibration.
Clean the fuser using HP Toolbox
NOTE: Use the following procedure to clean the fuser using the HP Toolbox. To clean the engine when the computer is running an operating system that does not support HP Toolbox, see the late-breaking Readme on the root of the CD-ROM, or visit http://www.hp.com/support/clj2600n .
1 Make sure that the printer is turned on and in the Ready state.
2 Open the HP Toolbox using one of the following methods.
On the Windows desktop, double-click the HP Toolbox icon.
* On the Windows Start menu, click Programs (All Programs in Windows XP), click HP , click HP Color LaserJet 2600n, and then click HP Color LaserJet 2600n Toolbox .
3 Click the Troubleshooting tab, and then Troubleshooting Tools .
4 Click the Print button next to step 1, "Click the "Print" button to print out the Cleaning Page."
5 Remove the Cleaning Page from the output bin, and load it printed side down in Tray 1.
6 Click the Clean button to complete the cleaning process. Press the GO button on the printer control panel. The Cleaning page will print, with a second page adhered to the first page. This is normal behavior during the cleaning process.
Cleaning spilled toner
Defective print cartridges can develop leaks. Also, after a paper jam has occurred, some toner might remain on the rollers and guides inside the printer. The pages that print immediately after the jam can pick up this toner.
CAUTION: When cleaning the printer, do not touch the ETB with a damp cloth or with fingers.
Cleaning the paper path
The device features a special cleaning mode to clean the paper path.
NOTE: If there is access to HP Toolbox, HP recommends cleaning the paper path by using HP Toolbox.
Clean the paper path
1. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press (SELECT).
2. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Cleaning Mode, and then press (SELECT).
A page feeds through the printer slowly. Discard the page when the process is completed.
3. Load plain letter or A4 paper when prompted.
4. Press (SELECT) again to confirm and begin the cleaning process.
Calibrating the printer
Calibrations are performed at regular intervals. For best print quality, a calibration can be performed from the control panel using the following steps:
NOTE: This will calibrate the color and clean the black electrostatic transfer belt (ETB).
1 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select System setup and then press (SELECT).
2 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Print quality and then press (SELECT). Calibrate color will display on the control panel.
Press (SELECT).
3 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Calibrate now and then press (SELECT).
4 Press (SELECT) to start the calibration.
Other options for print quality defects that still persist
Oct 26, 2010 | Office Equipment & Supplies
I can turn my hp pavilion dv6810us on, but the screen stays black what can I do to fix this?
Turn the computer off completely ,disconnect any external devices connected to the computer along with the cable for the internet .Then press and hold the power button on the front panel of the computer tower and then hold it for atleast 30 seconds.Turn the computer on and check what happens.
Turn the computer off and then as soon as you turn the computer on tap the f8 key repeatedly until you get a black screen that says advance boot menu options ,select the option that says safe mode and hit the enter key .Select the operating system if you have xp or else you need to wait for the page wherein you can put in the password.If it is sucesful then it will take you to the desktop so you need to restore the computer to an earlier time when the computer was working fine.Click on start?all programs ?accessories?system tools and then system restore .(in case of vista simply type system restore in the search bar and hit enter). Once the resotre page opens up select restore my computer to an earlier time and click next.You will get a calander whic has different dates so select a date when you think that the computer was working fine.The date that you select should be in bold.Click on nest next to exit from the wizard and then the computer will restore and then will restart which wil take you to the normal mode.If the restore is succesful then it will take you to the desktop .
If safe mode does not work try with last known good configuration which takes the computer to the date when the computer was working fine.If non of the options work then you can go to the recovery page to do this instead of the f8 key tap the f11 key until you get the system recovery page then click on next to get to a page that says advance option ,need to click on that and then select system restore .This is for xp in vista its the same key (f11) but you get a recovery manager page then you will have to select advance option then system restore .
If these options does not work then recovery needs to be done wherein the computer needs to be formated.
May 11, 2010 | HP Pavilion dv6810US Notebook
KEYBOARD PROPLEM
Hi Sam,
Sorry your problem got left in the que for a while, but Lee apparently wasn't familiar with that keyboard. You do have an extra key near the start button that activates the Tags and other coloured symbols while in french or multi language mode. Simply use it like a shift key.
If you're not using the HP to type in french and don't require the accents you can change the setting in windows to tell the computer that your keyboard is a US english keyboard which will reassign all the keycodes to the "normal" locations by english speaking standards.
To do so, open your control panel, click on the classic mode link if it's not already in classic mode(20+ icons). Then click on the regional settings icon. Depending on wether you have Vista or XP the panel varies slightly XP has a keyboards tab, Vista has a Input Devices tab. Either way go to that tab and click the button to adjust input devices, on the page that pops up you will see a list of available, installed keyboards. If US english isn't listed click the ADD button find it in the list and add it.
If you only type in english, remove all other keyboards. If you use french as well, remove all but the canadian french/canadian multilingual depending which you have(if you don't know follow instructions below to find out). Then OK out of the window. OK the regional settings window and close the control panel. If you only select US english you're done, if you left French as an option you will see a small blue icon to the left of the clock, you can click on it at any time to switch between your installed keyboard modes.
Hope this Helps FixYa!
Chris
Model info for your product can be found at www.hp.com click Support & Drivers, then select the Knowledgebase button on the next screen and type in your full model number or allow the automated link to check your model online. When it launches your product page select Product Specifications from the long list in the middle and if it brings up a second list select the same.
You can now scroll down the specs and your keyboard will be listed as either Canadian English/French/Multiligual, all three have some variation of the keys you described.
Apr 11, 2009 | HP Computers & Internet
My HP PSC 750 printer screen seems to be in German. How do I get an English display? Diana
CLICK HERE for your owners manual in PDF format.
Page 36 of the manual states the following -
HP PSC 700 Series
The following steps help you change the language for your unit.
To do this using the front panel
Press Menu.
2 Press until Maintenance appears, and then press Enter.
3 Press until Set Language and Country appears, and then press Enter.
4 Press until the desired language appears, and then press Start Copy, Black or
Color.
5 Press Start Copy, Black or Color to confirm.
A prompt displays asking to select the country where your HP PSC will be used.
Specifying the country sets your photo sizes applicable for your region.
6 Press until desired country displays, and then press Start Copy, Black or
Color.
7 Press Start Copy, Black or Color to confirm.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 04, 2009 | HP Office Equipment & Supplies
Cant get it to read in english
Change the front-panel country or language on HP PSC 750. (From HP PSC 750 manual - bpu02250.pdf)
1 Press Menu.
2 Press a194261.gif until Maintenance appears, and then press Enter.
3 Press aa48bd2.gif until Set Language and Country appears, and then press Enter.
4 Press 98782b3.gif until the desired language appears, and then press Start Copy, Black or
Color.
6 Press b3bb801.gif until desired country displays, and then press Start Copy, Black or
Color.
Feb 01, 2009 | HP PSC 750 All-In-One InkJet Printer
Multiple page faxing
press fax then press faxtel nummer . put page 1 on the glass press start mono (b/w mono) You will be asked if there are another pages. Press 1  and put the next page onto the glass. When finished press 2 (No, no more pages). machine will start calling and sending.
BTW Did you read the handbook? This is explained within the handbook which can be downloded from the brother homepage of your country!
Oct 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
Front Panel Display is Blank - only small black squares
the front panel display initializing and then disapear and then the functional buttoms begin to flash. nothing happen again. when i press the on buttom the same thing reocurre
Jan 06, 2007 | HP PSC 2210 All-In-One InkJet Printer
19 people viewed this question
jasbo
jasbo
