Depending on the model, two things you can try:
1. do a reset. there may be a small recessed reset button under the faceplate. Alternately, you may want to reference 1, 2, 3, 4. 5 or 6
2. remove the backup memory battery (if your model has one).
Other than that, it could be a firmware glitch and the corrective procedure would be to re-install/flash an update the firmware.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
WORLD CLOCK
1.on the menu page ,touch "TRAVEL KIT"> WORLD CLOCK.
2.to change a city listed ,touch the city.
3.select a new time zone (or city ) touch "OK" when done.
4.touch WORLD MAP to view a map.
5.nightime hours are shown in the shaded area.touch WORLD CLOCK to view the clocks again, or BACK to exit...
for more information click this site;..
http://shop.garmin.com
Try to set it again:
1/Verify the date and local time (this should be
the date and time according to the local date and
time of country/area you are in). Because the
time shows is Universal Time (UTC), you will
need to enter a time offset to display the correct
local time for your area.
2/Move the field highlight to the OFFSET field
and press Enter
3/With the arrows (←→), go to the figure which
represents the hours then with the up & down
arrows (↑↓), select the time offset for your
longitude and press .
4/Move the field highlight to the HOURS field
and change to 24 if that is not already the case.
5. Press QUIT , to return to the MENU Page, then select
Navigation Setup “NAV SETUP” with the Up & Down arrows (↑↓)
then press ENTER
Hope that helps.......
Need to set the clock on the Naxa mp3 player in order to play my music. Please help!!!!!!
