Question about Brother HL 1440 Laser Printer
Alarm/data button on
My alarm and data button stays on continuously after I've changed the toner. How can I reset this?
  • 1 more comment
  • sirjames22 Jul 01, 2008
    That did the trick; thanks!
  • ureichman Jul 04, 2008
    Alarm and Data are on continuously. I did shake the toner (not a new toner) but it did not help. What can I do?
  • weija09 Aug 28, 2008
    Alarm/Data lights are on constantly and printer will not print. I know there is an optical sensor that reads the amount of toner left in the cartridge. Where is this sensor located, and where on the drum/cartridge does it view? also what is the procedure to reset the printer alarm light(s).
    Thanks
    Weija
  • 134 Answers
Try shaking the toner side to side. It reads the toner level with a photo sensor. If there is no toner in the window then it will read empty.
Posted on Jun 30, 2008
Brother HL-1435 printer not printing. Alarm and data lights stay on. I tried replacing the toner, replacing the drum, factory resetting printer (both are genuine Brother products), uninstalling and...
try reseting drum unit
Open the front cover. Locate the black button under the LED lights on the left side. Press and hold in the button until all the lights are lit. Release the button. The counter is reset!
its toner soup
Nov 18, 2013 | Brother HL 1435 Laser Printer
Reset drum counter
I found this solution online for you:
Shut off the printer.
  • 2 Hold down the "Continue" button while opening the front door. Then turn on the printer.
  • 3 Keep the Continue button held down until only the "Error LED" is on then release the button. Close the door.
  • 4 The Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit up.
  • 5 Press "Cancel" a few times to cycle through the LEDs until just the "Toner Low LED" is lit.
  • 6 Press and hold the "Continue" button until the LEDs cycle through and release only when the LED stops at Toner Low.
  • 7 Turn the printer off and back on.
  • Mar 27, 2013 | Dell 3100cn Laser Printer
    Dell 1320c won't recognize new toner
    It's possible to be the chip failure. Try to change the chip or reset them (using an chip reseter). Also you can search for service manual on the internet. In the manual you can find more possible causes of your printer failure and how can repair it.
    Mar 24, 2017 | Dell 1320c Laser Printer
    Reset counter
    By the way, what is the make and model of your printer?
    1. Resetting the Drum Page Counter
      • 1 reset-counter-dell-laser-printer-1.1-800x800.jpg Toggle switch in back of the printer. Shut off the printer.
      • 2 reset-counter-dell-laser-printer-1.2-800x800.jpg Front door opened Hold down the "Continue" button while opening the front door. Then turn on the printer.
      • 3 reset-counter-dell-laser-printer-1.3-800x800.jpg Error LED lit Keep the Continue button held down until only the "Error LED" is on then release the button. Close the door.
      • 4 reset-counter-dell-laser-printer-1.4-800x800.jpg Top 3 LEDs lit. The Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit up.
      • 5 reset-counter-dell-laser-printer-1.5-800x800.jpg Toner low LED lit. Press "Cancel" a few times to cycle through the LEDs until just the "Toner Low LED" is lit.
    I hope you find it very helpful. Best regards.
    Aug 16, 2011 | Office Equipment & Supplies
    Ready light doesn't stay lit, alarm light is red
    Because I was getting gray shading on my pages and data was still being printing, I decided to change the toner cartridge. Now the pages are clean and white and all the lights function properly. Most cartridges that are running on empty don't print any data at all or at least print the data at the top of the page and gradually gets fainter sp? on the page. Who would have thought just by changing the cartridge would solve the problem? So glad that's all it was........wasn't excited about having to buy a new printer.
    Jul 22, 2009 | Brother HL 1440 Laser Printer
    Drum light, alarm light and data light stays on. Does this indicate that the drum and toner need to be replaced?
    Yes, drum light means drum is nearly used up, and alarm plus data means the toner is almost gone.
    Jun 19, 2009 | Brother HL 1440 Laser Printer
    I have changed the toner in my printer and the toner light continues to stay on/won't print. I tried changing the drum and still the toner light stays on/won't print. I tried opening the toner door and...
    No guarantee this will work but I refilled toner on my Brother 5170 and it only worked after making sure the old stuff was completely out. After removing the little plastic plug, I tapped out the toner repeatedly on the side of a trash can (like 50 times) then took a shop vac and let that **** out whatever toner was left. It really seems to be important for some reason to rid the cartridge of ALL old toner before adding the new stuff. Hope this helps!
    Feb 23, 2009 | Brother HL-2040 Laser Printer
    Drum light on Ready light on Alarm light on Data light on
    Alarm and Data lights on together is from low toner. If shaking of the toner cartridge is not helping, change the toner.
    Drum light is usually on because of the print counter. If the print quality goes really bad, change the drum and reset the counter by holding the front button wile the front cover is open till all lights come on. Release the button and close the cover.
    If just Data light is on, check the print ques, some jobs might got stuck there.
    Apr 28, 2008 | Brother Office Equipment & Supplies
    Printer won't print
    According to the operation manual: If alarm light and data light blink every 5 seconds- TONER LOW (purchase more toner and have it ready when the 'toner empty' is indicated). If alarm light and data light stay lit- TONER EMPTY (replace toner cartrige with new one).
    Apr 21, 2008 | Brother HL 1440 Laser Printer
    Brother Laser Printer HL 1440
    tray this
    The procedure for the factory inspection mode is as follows.
    (1) Turn off the printer power switch, open the front cover, and remove the drum unit.
    (2) Turn on the printer power switch while holding down the control panel button. The Drum
    LED comes ON.
    (3) Lightly press the panel button again.
    (4) Check that all the LEDs except the Ready LED are OFF.
    ✒ If the toner sensor is ON, the Drum LED stays ON (error).
    ✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
    ✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
    only)
    NOTE:
    The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
    (5) Check the rear registration sensor.
    ✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
    ✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
    any time. (error)
    (6) Check that only the Data LED comes ON while pressing the panel button.
    ✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
    ✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
    If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
    the Ready LED also stays ON. (HL-1250 only)
    NOTE:
    (7) Install the drum unit.
    ✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
    (8) Close the front cover.
    (9) Continue to press the control panel button.
    ✒ Check that the Data LED stays OFF.
    (10) Release the panel button.
    (11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
    status.
    If any error is detected, the printer stays in the inspection mode.
    Apr 01, 2008 | Brother HL 1440 Laser Printer
    Brother HL 1440 Laser Printer Logo
    146 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
