Question about Copystar CS-1500 Copier
I need to print a config page to see print volume.
I would like to print a configuration page, to determine copy usage. I can't find the manual, and don't know the menu system. Any help would be appreciated. Thanks, Jeremy
  • 38 Answers
Very easy, press and hold the orange stop/clear button for 5 seconds. you'll see the display will first show ---, then 3 number, and another 3 numbers. this is your copy counter. if you would like to print this, follow the procedure above but as soon as the --- is shown on the display, press the green start button
Posted on Jul 24, 2008
Config page on hp4345 without menu button
You would need to log into the embedded webserver to view the configuration page. From there you could screen capture it as I do not believe that the print config page was added until later models.
Oct 31, 2014 | HP LaserJet 4345mfp Printer
Tip
How to print a config page on a Ricoh printer
On Ricoh printers, the configuration page (also called the Config page) is an information page that can be printed out with detailed data about the machine's status. The Config page shows the printer's copy count, various network settings, and current firmware versions, among other things. One nice feature of the Config page (on most printer models) is that it shows how much toner is left in the cartridge or bottle, so you can find out if you'll need to order more soon.
Follow the steps below to print a Config page from a stand-alone Ricoh printer.
A. Turn the printer on and wait for it to warm up.
B. Press the Menu button.
C. Scroll through the list of submenus using the up and down arrow keys until you see List/Test Print, then hit the OK button.
D. Look for the Config Page option, and hit OK again.
The configuration page will print out, and depending on that specific printer, it might be two pages rather than one. Whether the printer is black and white or color, the configuration page will be printed in black and white. If you want to print a test page in color, scroll further down the List/Test Print menu and you should see something called the Color Demo page.
To print a Config page from a multifunction Ricoh printer (one that scans and copies as well as prints), the steps are similar, but some of the machine's buttons are different. Multifunction printers typically don't have the Menu button, so you would press User Tools instead and then go to Printer Features. From there, the process is pretty much the same as described above.
on Jun 19, 2010 | Office Equipment & Supplies
Xerox 3500 config page
To print a configuration page from a Xerox Phaser 3500:
- Press the Menu button
- Information will be displayed on the screen -- press OK
- Go to Info Pages, and press OK
- Go to Config Page, and press OK
To get configuration page instructions for other copiers, printers, or fax machines, go to How to Print Configuration Pages.
Nov 10, 2010 | Xerox Phaser 3500/DN Laser Printer
I HAVE A RICOH AFICIO SPC 811 DN HOW CAN I SEE HOW MANY COPIES I HAVE PRINTED THANKS
Hi, you can view the number of pages printed by printing out a configuration page. To do that, press the Menu button, then find the menu labeled List/Test Print and select it. There will be an option for Config Page -- select that and the configuration page will print out. The number of prints you've made (both for black & white and color) will appear toward the top of the page.
Hope that helps!
Oct 18, 2010 | Ricoh 8200DN Laser Printer
How i can print configuration page on oki 321
Turn the printer on. Hold down the Shift Button and push SEL. This will put it in configuration mode. Release the Shift Button and press PARK to print a config page. If you need a user manual for the 321, here's a link to a .pdf download... http://www.precision.com/manuals/Okidata_ML320_321_Manual.pdf
Dec 12, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Ho do I print a config page from the extend print
If I remember correctly there is a reset/print configuration button on the pocket print server. With it connected and the printer on, press it once and it should print out a configuration sheet with its settings. If that doesn't work, disconnect the power and with the button held in, reconnect the power and release the button.
Oct 09, 2009 | Extended Systems Computers & Internet
How do i check the how many pages were printed out
dear friend
just press menu
then you will find reports press ok
then you will find config report or something like that
press ok
you will get the print
thanks
Apr 10, 2009 | HP LaserJet 3055 All-In-One Printer
Tally6215 "Config 1" Error
The 'Config 1" message on the T6215 is not indicating an error message, this message is simply indicating that Config 1 of the 10 configurations that you can set on the T6125 is loaded.
With the Config 1 message loaded you should still be able to print so long as the printer is ONLINE and does not have any other error lights on.
If the printer is not printing I would recommend printing a configuration page to check the printer is working OK.
To print a configuration page follow these steps;
Put the printer OFFLINE
Press the MENU BUTTON
Press the DOWN ARROW to HELP
Press ENTER
The printer should print a configuration page, if this prints correctly I would recommend checking the settings in particular the Interface and Emulation settings.
I would also recommend checking connectivity between the system and the printer to check the print jobs can get to the printer.
Also check the system to ensure the correct printer driver and printer setup is being chosen.
Mar 26, 2009 | Tally T6215 Matrix Printer
CANNOT FIND METER COUNTER ON MACHINE?
Print a configuration page. It will be on there. Menu, lists/prints, config page.
Feb 22, 2008 | Ricoh Aficio BP20N Laser Printer
Copystar CS-1500 Copier Logo
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Oloyede Monsuru
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
