Question about HP Pavilion DV1010 Notebook
DEAD LAPTOP Not battery or adapter problem. How to troubleshoot and resolve.
    Genius:
  • 2,028 Answers
Check the jack on the computer to see if it's loose. If so, it will need to be resoldiered or replaced. Sometimes it's hard to tell if a soldiered connection has broken loose, there are three pins that soldier to the board and if one breaks loose it can cause this. If the jack is good, then I'm afraid this may be a motherboard problem. You'll need to take it in and have it checked out.
Posted on Jun 30, 2008
I just had the AC Adapter connector replaced on my motherboard. I cannot use the laptop without the AC plug in, presumably because the battery is dead. When I plug in the AC adaptor plug the Amber
The company that repaired your laptop did not do a proper job. They should not charge you for further work. I suggest you take your complaint to your government consumer complaint office to get this problem resolved.
Aug 04, 2012 | Dell Computers & Internet
Dell Inspiron 1521 battery not charging
Laptop batteries power a laptop when it is not connected to an electrical outlet. If the laptop battery fails to charge when the laptop is plugged into an electrical outlet, the battery is likely dead and needs to be replaced. Unfortunately there is no way to fix a dead battery. However, while a dead battery is the likely cause, it is not the only cause. The AC adapter may be broken, in which case the battery won't charge, or the battery contacts may be dirty and need cleaning. Prior to replacing the battery, perform simple tasks to ensure a dead battery is the cause of the problems.
1.Power down the laptop. Gently pull the AC adapter from the side of the laptop for removal.
2.Place the laptop in front of you, bottom side up. Locate the battery release mechanism. This can be a button that slides or needs to be pushed to unlock or release the laptop battery from the housing unit. Press or slide the mechanism. Slide or lift the battery from the battery bay for removal.
3.Insert the AC adapter into the side of the laptop. Power on the laptop. If the laptop does not power on, ensure the AC adapter is securely plugged into a working electrical outlet. If the electrical outlet is working and the laptop won't power on, the AC adapter is not properly working and needs to be replaced. Remove the AC adapter.
4.Dip a cotton swab in a small amount of rubbing alcohol. The cotton swab should be damp, not dripping wet. Lightly rub the dampened cotton swab onto the battery contacts and battery bay contacts to remove dust, buildup and grime. Allow the contacts to air dry.
5.Align the battery over the battery bay. Either press or slide into place. A clicking or snapping noise produced from the locking mechanism will confirm the laptop battery is securely locked into place.
6.Install the AC adapter. Allow the AC adapter to fully charge the battery for 8 hours.
7.Remove the AC adapter. Power on the laptop. If the laptop does not power on, the battery needs to be replaced.
Sep 01, 2011 | Dell Inspiron 1521 Laptop
I have a DELL Vostro 1500 laptop, since the last 2 weeks it appeared a message when i turn on my laptop, it says: " The AC power adapter wattage and type cannot be determined. The battery...
Certain models talk to a chip in the adapter, sounds like this one has gone bad. At this point you can live with, buy a new one or pick up a used. This is a fairly popular model and you should be able to locate one from a dead laptop.
Mar 06, 2017 | Dell Vostro 1500 Notebook
Totally dead, replaced ac adaptor, which was dead too, did not help. still dead.
Hello, I am thinking that your battery needs to be replaced as well. Possibly because of the stress it took from your ac adapter issues. So, to check to see if the issue at hand is now your battery... 1) UNPLUG THE AC ADAPTER FROM THE LAPTOP. 2) REMOVE THE BATTERY. 3) PLUG THE AC ADAPTER BACK INTO THE LAPTOP 4) TURN IT ON.
If the battery was now the issue, your laptop should have turned on at this point.. If it did NOT turn on, then there is a different issue that we should troubleshoot. Let Me Know, ok?
Sep 10, 2010 | HP 6530b Notebook
I plug in my AC power adapter and the laptop won't recognize that it is attached. The light in the front of the Laptop doesn't turn on and now the laptop is dead so I am unable to use it at all.
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 06, 2010 | Toshiba Satellite M35X-S149 Notebook
My notebook toshiba portege m300 was dead. but when i push the power button the indicator power is on and there was nothing appear in the LCD
Sep 05, 2010 | Computers & Internet
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
I just bought a replacement 9 cell battery and a 90 watt power adapter for my Dell E1505. With the new battery and power adapter my battery indicator light keeps flashing green and the battery doesn't...
If a new DELL ac adapter (3rd party Adapters are not recognized and the charging circuit is disabled) and a new battery doesn't resolve then the charging circuit on the motherboard is bad
Dec 29, 2009 | Dell Inspiron E1505 Notebook
My laptop is a Sony Vaio PCG-6Q2M with Power and Battery Problems
The best advice would be to update the BIOS and then go to the BIOS utility and restore the settings back to default. This might resolve the issue if it is software related. If not then visit the manufacturer's website and download the latest chipset drivers. Restart.
Try using a different power adapter of the same kind and check for the issue.
Turn off system and remove the power cable and battery and press the power button for about 30 seconds to power drain the system.
Turn on and check.
If not the main board itself is the issue for which I would request you to contact the manufacturer.
Sep 10, 2009 | Computers & Internet
Laptop
sound like a bad motherboard
Jun 26, 2008 | Computers & Internet
HP Pavilion DV1010 Notebook Logo
67 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
