TO update the phone software you can contact the your mobile care authentic units or one the mobile you go to settings ->phone mgmt->options->software update.
NOTE:you may require internet connectionand data charges may apply
Nokia PC Suite - if you don't have a memory card you can use the Nokia PC Suite software to do the backup; the software comes on a CD with your phone but if you don't have it you can download it from the Nokia website (you'll need USB cable to connect your phone and pc)
2. Charge your battery - this is very important; charge your battery to the full power before starting the update process; if you run out of battery in the middle of updating you can seriously harm your phone (it probably won't even start up)
3. Download Nokia Software Updater - install the updater; this piece of software will guide you through the whole update process; you might need to unblock it in your firewall
4. Launch the Nokia Sofware Updater - from now on it's really simple, just follow the guide and you'll be fine; the whole updating process takes several minutes to complete, don't try to cancel it in the middle in any case, your risk damaging your phone; in my case it took about 15 minutes to complete; USB cable needed again
5. Restore your data - if you used a memory card for backup then you simply go to the Tools - Memory select Options - Restore from card; if you used Nokia PC Suite you have to connect your phone to the pc via USB cable, select Backup and Restore
Now you have your phone loaded with the newest software. If you experienced some problems with your phone performance before the update process should fix it. So go on and check it out. To make sure your phone is really updated type *#0000# when in idle screen and check the software version. Hope it helped :)
digg_url = 'http://digg.com/software/How_To_Update_Your_Nokia_Phone_Software';
Check out the Nokia Software Update FAQ!
se your phone's SW update feature to get software updates over the air or via Wi-Fi - no PC needed.
Please note that not all device updates are available over-the-air. To see what the latest version for your phone, see the "Can I Update" section of Device Software Updates.
To learn more about SW update and its benefits, see the "How to" section of Device Software Updates.
Set your device to alert you when new software updates are available.
You may also be able to update individual applications even if there is no software update available for your device.
