2001 Volkswagen Beetle Logo
Posted on Dec 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced the O2 sensor unit and the ECM(programs installed) but I'm still getting CHECK ENGINE LIGHT(P0001). what is the possible problem and how can this be resolved?
William Robinson
Level 3:
Genius:
  • Master 1,547 Answers
  • Posted on Dec 13, 2010
William Robinson
Master
Level 3:
Genius:
Answers
1547
Questions
0
Helped
502076
Points
4729
P0001 Fuel Volume Regulator Control Circuit/Open The above code is about an oxygen sensor code for the heater circuit located in bank 1 sensor 1. (bank 1 is at exhaust manifold by the #1 cylinder head, bank 2 is on the 2nd cylinder head. On some engines, both exhaust manifolds could have one oxygen sensor each side and the 2nd cylinder head will have the sensor 2). On the oxygen sensor itself, it has 4 wires which are color coded. Two of wires are for the heater circuit that heats the oxygen sensor to make it reach optimum operation quickly. Those 2 oxygen sensor heater wires could be shorted between the sensor and the ecm (engine computer) or other engine components.
Replaced the O2 sensor unit and the ECM(programs - oxygen%20sensor%20heater%20copy.jpgThe common fix for this code is to check the integrity of the heater wires. Check the wires for insulation and routing which could be loose or touching a hot exhaust that can short the wires. If the engine has too many miles, it is possible that the heater circuit inside is worn and shorted which needs a replacement of the oxygen sensor. If you have a DVOM, you can also test the continuity of the heater wires from the oxygen sensor to your computer pins.
More detailed fixes will be provided as soon as you give the symptoms of the obd2 trouble code. ATS will provide the wiring diagram so you can trace the color coded wires. Use an obd2 code reader or scanner so you can access this obd2 trouble code. When you have this obd2 code list, use it as a reference and give the code to ATS. We will then send you all the possible fixes for the obd2 trouble code. ATS has lots of fixes for obd2 gm codes, obd2 ford codes, dodge obd2 codes and all obd2 import codes such as Toyota obd2 codes, Honda obd2 codes, Nissan obd2 codes, etc. All fixes for this obd2 codes are guaranteed or your money back.
Important TIPS about Oxygen sensor:
The oxygen sensor content of the exhaust gas indicates when the engine mixture is operating lean or rich. When the oxygen sensor detects that the engine is operating rich, the signal voltage is high, and any decreases in the signal voltage means the engine running is lean. The engine computer supplies a reference voltage like one volt or five volts, and then shows the change in the sensor return voltage as the sensor's resistance is changing. If you have connected everything properly, when you crank the engine, you should see the check engine light coming out.
Unheated oxygen sensors rely on the heat of the exhaust gases to reach the working temperature, therefore they might start to cool down while the engine is idling and revert back to a default air-fuel ratio setting. This type of sensor usually has a single wire connector, though others have two. Unlike the fuel pump relay, the 02 sensor heater circuits have a separate fuse for each sensor and grounds, which are controlled by the engine computer.
To read a voltage across the heater, one side must be connected to (+) and one side must be connected to (-), which is accomplished by the computer or a transistor. It can read 12V between each wire and a separate ground if it was connected to positive and the other was not yet connected to ground connection (for details, please contact ATS).after you replace oxygen sensor you have to drive for so many miles before it resets its sef
Why does my 2000 Dodge Ram van 3500 suddenly stop running at highway speeds?
the o2 sensors are responsible for part of the fuel management. You need a good auto-electrician.
My check engine light is on. it is pulling 4 codes P0302 P1670 P0174 P0171
code p 0302 is a misfire on no 2 cylinder
check that the plug lead is on properly, that the lead is operational
move the injector from 2 to another cylinder and see if the misfire follows the move
code p 0174 refers to system too lean bank 2===causes intake /exhaust leak---fuel pressure / pump---injector/s--AIR system--hose connection/s
code p 0171 refers to system too lean bank 1=== causes intake /exhaust leak---AIR system---MAF/VAF sensors---fuel pressure / pump---injector/s -- HO2S
You stated that you replaced the O2 sensor but that is different to the HO2S sensor , does a different job and controls the air/fuel mixture from the ECM
because it has banks 1 and 2 it is a v engine and you will have a HO2S in the exhaust manifold or before the cat converter for each exhaust
O2 sensors are after the cat converter and confirm the HO2S settings for the ECM
to put the lights out , use a scan tool to reset the ECM
1helpful
Engine Service Soon Light On code P0154
Error Code: P0154
Description:
Heated Oxygen Sensor (HO2S) 1 , Bank 2 - No Activity Detected
Problem areas:
- Wiring.
- Open circuit in signal wire, between Heated Oxygen sensor 1, Bank 2 and ECM. (Must check and confirm)
- Heated oxygen sensor (HO2S).
- Engine control module (ECM).
P0160 code repair
Always buy OEM sensors.
What is p1148
P1148 - Closed Loop Control Function Bank 1
This mean that the closed loop control function for bank 1 does not operate even when vehicle is driving in the specified condition.
The Powertrain Control Module (PCM) or Electronic Control Module(ECM) monitor the function of the Front Oxygen (O2) sensor or Air/Fuel (A/F) sensor by comparing the signal with the Rear O2 sensor.
Symptoms:
- Engine Light ON (or Service Engine Soon Warning Light)
Possible causes:
- Harness or connectors Front Oxygen (O2) sensor or Air/Fuel (A/F) sensor 1 circuit is open or shorted.
- Front Oxygen (O2) sensor or Air/Fuel (A/F) sensor bank 1
- Front Oxygen (O2) sensor or Air/Fuel (A/F) sensor bank 1 heater
Possible solution:
- Repair harness or connector. If repair is needed
- Replaced Front Oxygen (O2) sensor or Air/Fuel (A/F) sensor bank 1
Then, possible causes are faulty harness or connectors to the air fuel ratio sensor, a faulty air fuel ratio sensor (1) or faulty air fuel ratio sensor (1) heater. Most likely yes it is just faulty sensor. Just replace this devices and reset the stored codes.
Keep us updated.
4helpful
Check Engine light code P0432
P0432 - Main Catalyst Efficiency Below Threshold Bank 2
The ECM or PCM monitors the front an rear O2 sensors. The ECM or PCM detects Warm up Catalytic Converter when the sensors are out of specifications.
DTC is set when the ECM or PCM detects rear HO2S value difference becomes closer to value of front HO2S. The ECM or PCM monitors when vehicle speed is 25-60 MPH, load is 22-45 percent and engine speed is 1000-3000 RPM.
Symptoms
Possible causes
- Warm Up Three Way Catalytic converter deterioration or malfunction. - Exhaust system leaks. - Loose front or rear HO2Ss. - Front HO2S malfunction. - O2 sensors harness or connectors
Possible solution
- Replaced Catalytic Converter - Replaced rear O2 sensor - Repair wire harness or connectors
Check it ans tell us news.
1helpful
8/2009 computer programming failed, threw a rod and I replaced the engine in my 2001 Nissan Pathfinder. No failsafe mode apparently. I replaced both front O2 sensors and installed a new computer and had...
P0134 and P0154-o2 circuit not actively detected-bank 1 and 2, side 1
Nissan TSB Reference # NTB02-015 (in canada). Might be a similar TSB in the US-also this;
It does sound like it is an electrical problem, possibly in a harness (damaged) or the ECM had major issues that a reflash could not overcome.
1helpful
P0426
P0420, this code comes ON when the O2 sensors reading go out of the range set by the factory. In some other models, the factory increased the range of the O2 sensor with a new program for the Engine Control Module (ECM), because the O2 sensors are still consider to be in normal operation. If the code comes back, I recommend reprogramming the ECM first. dealer has to program ecm try changeing your cars thermostat it also may shut off light before going to dealer
1helpful
Service engine soon Light On code says o2 sensor but replacing didn't fix it
There are two O2 sensors...one before the catalytic converter and one after. The one before is the one the ECM uses to control engine controls and the one after is there to verify the converter is working. if the converter stops working properly that can set off the O2 sensor error. It is possible that the catalytic converter could be the problem and not the O2 sensor. Or the O2 sensor that you replaced might not be the defective one. Also the check engine light might not go off right away after replacing the sensor. It may take some time of driving. The ECM needs to get a good reading from the sensor for sometime before the code will dissapear. So it is possible that you might have repaired the problem and the code has not cleared yet. You could clear the code by disconnecting the battery for about 10 minutes and then see if it comes back.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
