Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Home Network issues
I have DSL into a Actiontek DSL Gateway wireless
a netgear switch (10 rj45)
5 laptops (4 wireless)
2 Desktops
1 color laser printer with network connectivity
How do I connect it all together?
I can get to my internet but all but one computer can print.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
> you need to configure your wireless printer so that all computers will be able to detect it,your ISP or printer manufacturer will be able to configure that for you
Posted on Jun 15, 2010
Netgear rp614v4 as a switch
This router acts like a switch automatically, you can converse between ports on the same LAN connections without any setup.
They all need to have the same network setup, the same gateway address and DHCP setup.
If you are not accessing the internet that's all you need.
See manual http://downloads.netgear.com/pub/netgear/files/RP614v4_RM_12Jun08.pdf
Apr 02, 2014 | NetGear RP614 4 Port Cable/DSL Router with...
Can you help me configure my netgear router? I cant seem to connect to http://192.168.0.1
you can try typing in your browser address bar www.routerlogin.net then press enter this should bring up your routers setting wirelessly but this will only happen if your laptop detects your routers wireless network.
if you can connect your laptop to your router using ethernet cable you can go to the command prompt then type in IPCONFIG then enter this should pull up your ipaddress and the default gateway is your routers Graphical User Interface where you can go and change the settings, your Netgear default gateway should be 192.168.1.1 this is the default gateway that should show in command prompt for netgear routers.
If you are going to use wireless make sure in the router the wireless capability of your router is enabled ^_^
your settings depend on what your Internet service provider requires you for settings
Jun 21, 2010 | NetGear DGND3300 RANGEMAX DUAL BAND...
Trying to connect wpn824 router though dsl with Windows 2000
First make sure that you can access internet through the router when connected to it wired. If yes, then please perform the steps below to configure settings:
1. Open the browser(Internet Explorer or Mozilla Firefox) on a computer connected to the router.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'.
6. Set the 'Authentication Type' as automatic.
7. Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
10. Click on Wireless Settings under Advanced in the left hand side menu.
11.. Click on Setup Access List. Uncheck the option Turn Access Control on and click apply.
Scan for the wireless network on the computer with the wireless adapter and connect to your network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 18, 2009 | NetGear RangeMax WPN824 Wireless Router...
Macbook and I-touch loses wireless connection with versalink dsl
It sounds like the dsl modem and the gateway should be sync'd in the following way:
1. Turn everything off and disconnect the dsl for a bit. Make sure even the wifi stuff is off.
2. Turn on your gateway and let it cyce up.
3. Plug the dsl ethernet cable into your gateway, and to your phone line, then plug in the power to the dsl.
This will cause the dsl modem to "find" the gateway IP address and connect.
4. Turn everything else back on.
This should eliminate all the drops...
Let me knowhow it goes...
K
Jun 19, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Router / switch
For your type of varity the ideal harware would be a router. Preferably netgear.
May 30, 2009 | Computers & Internet
File sharing problem after installing Netgear DG834G ADSL/Wireles
- Run the Windows Network Wizard in each computer on the network.
Mar 10, 2009 | NetGear DG834G Router
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
Cannot access the internet after installing new NetGear router.
you need to change the IP address of the router. Plug just the router into the computer. Open Internet Explorer and go to 192.168.1.1. user: admin password:password. On the main page it allows you to change the LAN IP. Make it 192.168.2.1. Now unplug everything and rewire it correctly. This should fix the issue. Verizon uses 192.168.1.1 for the modem well so does Netgear and this causes the network to not function. So changing the IP of the router should fix this issue and has worked for me many times that I have done that set up.
May 26, 2008 | NetGear DG834G 54 Mbps 802.11g Wireless...
Apple user attempting to fix dad's dell laptop windows xp home edition
I'm confused because you say your trying to make a lan connection on the dell laptop but your connecting it via firewire into a DSL modem. doing this method would be a WAN connection and not a LAN connection. To make a lan connection you need to connect the laptop via network cable (or wireless connection) to a router that is connected to your actiontek dsl modem.
I can help you connect the laptop to the internet but 1st i need to know if your trying to connect it to a router or did you want to do a wan connection from the dsl modem.
Thanks,
Brad Nelson
Mar 15, 2008 | Actiontec (GT701WG) Wireless Router
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
