Question about NEC Dterm DTP 16D-1 Corded Phone
NEC DTerm80 phone
I need to program a headset for this phone. I already have it connected, but there has never had the headset programmed.
Can you help me?
  • 4 more comments
  • Anonymous Jul 03, 2008
    Same deal, headset is hooked up, but the headset feature is not enabled. The gal in my office has this feature as one of her speed dials and I want it.
  • Pattilane Aug 06, 2008
    I have an NEC Dterm 80, I want to program the phone to function with a headset, it is currenty disabled, need instructions to enable, also would like to find out what headset brands are compatible with the set. Thanks
  • popy428 Sep 24, 2008
    I have the same problem, I contacted our NEC rep and they said they have to come out and program a feature button at a charge of $115.00 minimum . Any suggestions would be greatly appreciated - it can be that difficult?
    M.
  • Anonymous Dec 12, 2008
    pick up phone with headset
  • mkuesterstef
    mkuesterstef Feb 08, 2012
    This is not a user programmable feature button. It is a button that must be programmed by a technician through system programming.
  • mkuesterstef
I have the 8 button phone and if you hook up your headset the right way you just have to press the line/feature access key all the way to the right instead of picking up the receiver. Keep the headset on all the time and just press that button to answer or hang up the calls. It works great! ( I have the Dterm80 telephone)
Posted on Oct 28, 2008
I am currently using the Plantronics Telephone Headset System S11 (Staples CDN $130) with my NEC Dterm 80 telephone system. It works well but until I program the feature option, I still have to lift the handset to answer the phone via the headset. Kind of defeats the purpose.
Posted on Sep 24, 2008
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
Sep 09, 2014 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm80 - how do you switch to headset
Press the headset softkey of programmed hard key.
Feb 18, 2010 | NEC Dterm DTP 16D-1 Corded Phone
I have a NEC Dterm80 I need to program a button on the phone to be my handset button so I may be able to use my handset. I dont what to have to call a DeltaCom tech in to program.
First and foremost we need to know what system you have. Then we can proceed with how to program the button.
NEC Elite 48, 192, IPK 1
First pick the button you want to program. Lets say button 13 in this example. Next check to see if that button is programmed by pressing Feature and that key. If that key says Vacant then it is available for use.
Next you will need to hit "Feature and 4" on that station to find the port #. Port # is Tel 10 for example. That means port 10 is where your extension resides.
Now type in "Feature, #, 0 *, 8974". The phone should say Program Mode. Now look at the Line Keys. These are the keys right above the # pad. Count from left to right 4 keys. Hit Line Key 4 and then type 12 on the dial pad.
Now that we are in key programming we need to enter the port of your phone. Make sure the blinking cursor is on the far left. If not press * to move to the left. Now enter 10 (port 10 or Tel 10) on the dial pad. The cursor should be right near the L. If not then press # to move to that position on the right. Remember * will bring you back to the left and # to the right.
This is where you are to enter the key #. In our example it is key 13. Dial 13 on the dial pad. Next we are going to change the key to a headset key by pressing "Recall, Line key 3". It should say H Set on the right. Now that you have the proper key set you need to hit transfer to write the programming. Remember to try and find a key that is not programmed, this will ensure that you don't undo any programming that is already in place.
Any other system other than the NEC 48, 192 or IPK 1 will not work.
Nov 17, 2009 | NEC Dterm DTP 16D-1 Corded Phone
I have a NEC Dterm80 phone system
you need to program call forward all to outside number
speaker, dial 42, enter 9 plus phone number
speaker
it must be allowed in class of service though
Apr 07, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Headset for NEC Dterm80
Do a search for a plantronics headset. All of theirs work well with NEC
Nov 11, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Connect/Program Headset
Sure you can do it. as long as the headset has a plug for the handset your fine. Plug it in and you will have to pick up and hang up the handset as needed. The headset key eliminates you having to pick up and hang up the handset to answer with the headset.
Feb 21, 2008 | NEC DTU 8-1 Corded Phone
NEC Dterm80 Phone
I have the feature button blinkin and i think the do not disturb is on help.
Mary
Nov 24, 2007 | NEC Dterm DTP 16D-1 Corded Phone
I need to program a HeadSet Button
For the DTU phone on an NEC Elite system:
Memory Block 4-12
put in the port number and the Lkey of the extension you want to make a headset key.
Programmin on a 16button phone, Lkey 11 needs to be lit and will display H SET to verify.
For the DTP phone, it is generally on an NEC 2000, which is entirely different.
Oct 12, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Dterm80 NEC phone
How do I get the following off my display?
MSG >>> In-Mail #2
Sep 12, 2007 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
1,914 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
