Question about Microsoft Xbox 360 Console
Help door keeps opening by its self wont stay closed
  • foster2 Sep 08, 2008
    Having the same problem.....door will not close and remains open, Any suggestions on how to repair it?
  • cweetrox Apr 24, 2009
    I had recently contracted the red ring of death. I used the fix on I-hacked.com and my 360 was healed. However, now the drive keeps ejecting.
  • 23 Answers
This is a known issue with the 360, most likely the cause is that the spindle that holds the disc is loose or completely broken off. As the way the cap for the spindle was made, microsoft used a magnet to hold it in place instead of glue or soldering as most drives would have. This is just another instance of inferior workmanship on their part to save money.
Contact 1-800-4MY-XBOX to get an RMA issued.If your console is out of warranty, open your console and get the model # of the DVD drive used in yours, then check online for any vendors selling replacements.
Posted on Sep 08, 2008
Whisper Drive garage door opens and closes by its self
try changing frequencys you might have a neighbor close by that is using same frequency as you causing your door to open when they open theirs
Jul 18, 2012 | Home Security
Door ajar light stays on and all doors are closed. What can I do without getting into a big expense
the door ajar switch is part of the door latch its self,some people have had good luck spraying the **** out of it with wd40,close the door and open it,and keep repeating.
Jan 22, 2010 | 2002 Ford Explorer
Front bay door wont stay closed
If you mean your cdrom drive wotn stay close, what can happen some times is the actually cdrom unit it self has shifted back inside its rack. try opening case and loosing a few screws here and there and shift it forward. make sure nothing has got stuck inside of door tiny bit of paper or anythign can cause it. hope this helps
Nov 28, 2009 | E-Machines eMachines Desktop PC
My oven door will not shut all the way. It
It is probably the self-cleaning latch that keeps the door from being opened during the self-cleaning cycle. Looks like it didn't retract all the way. Did you use the self-cleaning cycle? . Do this: Quiet the house down, open the door slightly and close it, letting it hit the obstruction. Do this again and again. You don't have to close it hard at all; in fact, do it gently. By listening, you will be able to hone in what is keeping it opened. Then go from there.
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
Cd/dvd door is opening and closeing all by it self
this is due to improper connection of wire from optical drive to motherboard i.e check whether the power cable/ide(sata)cable is not loose.Also clean their plugging area.problem will be solved.thanks.
Nov 23, 2008 | HP Pavilion a6544f Desktop PC
Fuel door wont stay closed
there is a little metal tesion bar/bracket that keeps it in the open or closed position. If your fuel door itself is not bent or damaged then I would check this bar to see if it has been bent or out of place. I'm not sure if there is a replacement part; I just bent mine a little to get it to stay closed. Unfortunatly I left it open the other day when I went thru a car was after fueling and the door is bent now so I have another issue to deal with.
hope that helps
Nov 12, 2008 | 1997 BMW 328
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Microsoft Xbox 360 Console Logo
137 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
